"Time > Sunrise AND Time < Sunset" doesn't work
I have two saved events, where I want to turn Off an outside lamp on Sunrise, and turn it On on Sunset.
Sunrise:
Sunset:
But it doesn't work! What am I missing?
Sunrise:
Sunset:
CaesarPL
Re: "Time > Sunrise AND Time < Sunset" doesn't work
Why blockly
? You can do it directly on the switch.
Oh, I did not know that. I will try that instead, thanks!
- jvdz
- Domoticz version: 4.107
For the record: The SunSet blockly is never true as that is pretty impossible when you think about it! Maybe an OR relation would be better for that one.
Jos
Jos
CaesarPL
Please check my example. When you press Timers, you can set time when you want to switch On or Off
Derik
- Domoticz version: BETA
you need to make a blockley more in this setup. because you use the extra if blockley...
Or you can use the base blockley.
olleman
I'm having a similliar problem but my blockly is a bit more advanced so I can't solve it directly on the switch.
My first condition (this one triggers as expected)
is "If PIR on AND Time: >Sunset AND Time: <22.00
Set whatever Switch on for 2 minutes
Second condition (this one doesn't trigger)
"If PIR on AND Time: >Sunset AND Time: <Sunrise
Any suggestions to what I'm doing wrong?
- kuifje
- Domoticz version: latest
When its >sunset it is <sunrise, and the other way around. You dont need the <sunrise of the >sunrise. And you dont need the if/else blocky but the one without the blue thing.
Good luck.
Kuifje
Good luck.
Kuifje
Xztraz
Set trigger on time and this works. (you'r script would trigger every minute between times)
aDJa
- Domoticz version: 4.9700
Hi there,
I had the same challenge, but also wanted everything in de blockly with sunset sunrise.
unfortunately i still had to use a dummy switch but i got the rest in de blockly.
see attachement:
p.s. the dummy has a sunrise and sunset timer but is also being turned off when the stairs are being turned off manually. (its not being turned on by the stairs)
see attachement:
OS: RPi4B, GH
ELECTRICITY: P1 Smart Meter USB
WATER: NPN inductive sensor
SOLAR: Omnik Inverter, PVOutput
LIGHTS: Philips HUE + GLEDOPTO + Yeelight
SENSORS: Xiaomi Temp + Humidity + Baro + Motion + HUE
