I want to show some "wind-values" from buienradar presented as separate sensor values.
When I create a virtual sensor with sensortype Wind, a sensor is created that can contain multile values.
How do I create a sensor for "winddirection", a sensor for "windstrength" etc ?
create seperate wind sensors (direction strenght)
elmortero
- Domoticz version: 3.9639
Re: create seperate wind sensors (direction strenght)
You could use dzvents to first read the separate values you want direction and then write them to the virtual sensors you create for them.
(for example: wDir = domoticz.devices('yourWindsensor').direction)
@elmortero,
I use dzevnts to split the separate values, but I first need to create the virtual sensors for every separate value
But when I create a sensor with the type wind, I get a sensor that expects 5 values. And I want to have a wind sensor with one value
- created device.JPG (19.17 KiB) Viewed 1508 times
elmortero
You should use custom sensors
That is an option indeed, but I would like to use it in Dashticz, that automatically can change windspeed into Bft which I prefer.
elmortero
This might be something for you. I don't know about Dashticz as I do not use it.
I made following (dzVents) script and created 4 virtual sensors:
- Beaufort - a custom sensor with Bft as axis Label
- Wind Condition - a text sensor with the Beaufort description
- Wind Description - a text sensor that shows the Beaufort conditions
- Sea Condition - a text sensor that shows the sea conditions
active = true,
timer = {'every 5 minutes'}
execute = function(domoticz)
local windDev = domoticz.devices('Wind') --declare your windspeed device
local bftDev = domoticz.devices('Beaufort') --custom sensor
local windCond = domoticz.devices('Wind Condition') --text sensor
local bftLand = domoticz.devices('Wind Description') --text sensor
local bftSea = domoticz.devices('Sea Condition') --text sensor with Sea Conditions
local windSpeed = windDev.speed --read windspeed value from your wind device
--description of labels mentioned below
-- bft: the Beaufort value as derived from Beaufort Scale based on current windspeed
-- bftTtext: wind condition as derived from Beaufort Scale based on current Beaufort value (from bft)
-- bftDescLand: Wind condigion description as derived from Beaufort Scale based on current Beaufort value (from bft)
if windSpeed < 1 then
bft = 0
bftTtext = "Calm"
bftDescLand = "Smoke rises vertically"
bftDescSea = "Sea like a mirror"
elseif windSpeed > 1 and windSpeed <= 5 then
bft = 1
bftTtext = "Light Air"
bftDescLand = "Direction shown by smoke drift but not by wind vanes"
bftDescSea = "Ripples without foam crests"
elseif windSpeed > 5 and windSpeed <= 11 then
bft = 2
bftTtext = "Light Breeze"
bftDescLand = "Wind felt on face - leaves rustle. Wind vane moved by wind"
bftDescSea = "Small wavelets still short but more pronounced"
elseif windSpeed > 11 and windSpeed <= 19 then
bft = 3
bftTtext = "Gentle Breeze"
bftDescLand = "Leaves and small twigs in constant motion. Light flags extended"
bftDescSea = "Large wavelets, crests begin to break"
elseif windSpeed > 19 and windSpeed <= 28 then
bft = 4
bftTtext = "Moderate Breeze"
bftDescLand = "Raises dust and loose paper. Small branches moved."
bftDescSea = "Small waves becoming longer. Fairly frequent white horses"
elseif windSpeed > 28 and windSpeed <= 38 then
bft = 5
bftTtext = "Fresh Breeze"
bftDescLand = "Small trees in leaf begin to sway. Crested wavelets form on inland waters."
bftDescSea = "Moderate waves. Many white horses"
elseif windSpeed > 38 and windSpeed <= 49 then
bft = 6
bftTtext = "Strong Breeze"
bftDescLand = "Large branches in motion. Whistling heard in telegraph wires. Umbrellas used with difficulty."
bftDescSea = "Large waves. Extensive white foam crests"
elseif windSpeed > 49 and windSpeed <= 61 then
bft = 7
bftTtext = "Near Gale"
bftDescLand = "Whole trees in motion. Inconvenience felt when walking against the wind."
bftDescSea = "Sea heaps up, spindrift begins"
elseif windSpeed > 61 and windSpeed <= 74 then
bft = 8
bftTtext = "Gale"
bftDescLand = "Twigs break off trees. Generally impedes progress."
bftDescSea = "Moderately high waves of greater length. Crest edges break into spindrift;"
elseif windSpeed > 74 and windSpeed <= 88 then
bft = 9
bftTtext = "Strong Gale"
bftDescLand = "Slight structural damage (chimney pots and slates removed)."
bftDescSea = "High waves, sea begins to roll"
elseif windSpeed > 88 and windSpeed <= 102 then
bft = 10
bftTtext = "Storm"
bftDescLand = "Seldom experienced inland. Trees uprooted. Considerable structural damage"
bftDescSea = "Very high waves, rolling becomes heavy."
elseif windSpeed > 102 and windSpeed <= 117 then
bft = 11
bftTtext = "Violent Storm"
bftDescLand = "Very rarely experienced. Accompanied by widespread damage."
bftDescSea = "Exceptionally high waves."
elseif windSpeed > 117 then
bft = 12
bftTtext = "Hurricane"
bftDescLand = "Devastation"
bftDescSea = "The air is filled with foam and spray, visibility seriously affected"
--updating the sensors if different from current so no unneeded updates are done
--read current info
local currbft = tonumber(bftDev.rawData[1])
--update info if beaufort changed
if currbft ~= bft then
bftDev.updateCustomSensor(bft)
windCond.updateText(bftTtext)
bftLand.updateText(bftDescLand)
bftSea.updateText(bftDescSea)
