electric meter
h143
electric meter
Post by h143 »
i have in my home an old ferrasi electical meter and want read it out with an esp8266 and domoticz,
i have it working based on thim, but i want my instant usage calulate on time between the pulsen is there a tutorial or can someone help me?
h143
Re: electric meter
Post by h143 »
Is there nobody who have this worki g?
olleman
Re: electric meter
Post by olleman »
Looking for the exact same solution
so +1
Antori91
Domoticz version: 4.10717
Re: electric meter
Post by Antori91 »
Domoticz High Availability Cluster: Synology Dz V4.10693 (Main) - Raspberry Dz V4.10717 (Backup) - Scripts Node.js
Alarm server: Raspberry - motionEye - iot_ALARM-SVR Node.js
Sensors/Actuators: ESP8266-Arduino
https://github.com/Antori91/Home_Automation
gerardwr
Re: electric meter
Post by gerardwr »
I use an Arduino sketch simulating a Youless powermeter. The Youless is a standard device in Domoticz, and report is like this:
Schermafbeelding 2017-10-05 om 17.26.33.png (34.63 KiB) Viewed 2654 times
The sketch runs on a Wemos Mini ESP8266 using just a phototransistor to monitor the time between led-pulses on the powermeter. Timing is then converted to actual Watt usage.
Let me know if you want to see the source of the sketch.
h143
Re: electric meter
Post by h143 »
gerardwr wrote: Thursday 05 October 2017 17:30 I use an Arduino sketch simulating a Youless powermeter. The Youless is a standard device in Domoticz, and report is like this:
That is where i am looking for can you explane how you have did it. In dutch is also good for me
gerardwr
Re: electric meter
Post by gerardwr »
h143 wrote: Friday 06 October 2017 23:51 That is where i am looking for can you explane how you have did it. In dutch is also good for me
Arduino sketch for ESP8266 attached below, with some instructions on connecting the phototransistor in the sketch (in Dutch).
This sketch has been running for me for more than 6 months without problems.
Youless_powermeter_clone_ESP_nointerrupt.zip
(2.94 KiB) Downloaded 176 times
As an alternative you can have a look at ESPEASY, that is able to measure pulselengths:
https://www.letscontrolit.com/wiki/index.php/ESPEasy
h143
Re: electric meter
Post by h143 »
Thank you i will try it today.
I have already run espeasy but that can not comunicate the pulse time to domoticz
