Dashticz - Module Moonphases
htilburgs
Post by htilburgs »
Hardware:
htilburgs
Re: Dashticz - Module Moonphases
Post by htilburgs »
As of sometime today (don't know exactly when), I've an error:
Error: EventSystem: in /home/pi/domoticz/scripts/lua/check_time_moon.lua: /home/pi/domoticz/scripts/lua/check_time_moon.lua:62: attempt to concatenate global 'moonriseMinute' (a nil value)
When I check manualy, then I see that the Moonrise is missing.
Has this something to do with Wunderground not sending the correct information?
"moonrise": {
"hour":"",
"minute":""
  "response": {
  "version":"0.1",
  "termsofService":"http://www.wunderground.com/weather/api/d/terms.html",
  "features": {
  "astronomy": 1
	},"moon_phase": {
		"percentIlluminated":"47",
		"ageOfMoon":"22",
		"phaseofMoon":"Waning Gibbous",
		"hemisphere":"North",
		"current_time": {
		"hour":"14",
		"minute":"56"
		"sunrise": {
		"hour":"7",
		"minute":"09"
		"sunset": {
		"hour":"19",
		"minute":"56"
		"moonrise": {
		"hour":"",
		"minute":""
		"moonset": {
		"hour":"15",
		"minute":"24"
	"sun_phase": {
		"sunrise": {
		"hour":"7",
		"minute":"09"
		"sunset": {
		"hour":"19",
		"minute":"56"
Hardware:
htilburgs
Re: Dashticz - Module Moonphases - Empty Moonrise
Post by htilburgs »
Just found and article from Wunderground on https://apicommunity.wunderground.com/w ... g-sometime
moonrise: {
  hour: "",
  minute: ""
moonset: {
  hour: "11",
  minute: "46"
This happens when a day does not have a moon rise. In this case, the moon rose yesterday.
And now for the million dollar question "how can we solve this in the source, when this happens" ???
Hardware:
EdwinK
Post by EdwinK »
So ,that was the problem
htilburgs
Post by htilburgs »
Yip, but now the solution....
Haven't found anything yet. I'm looking in the lua script, but nothing works (yet).
Maybe somebody has a great idea??
Hardware:
htilburgs
Post by htilburgs »
Ok, with some help I've changed the part of the script. That should avoid giving an error and in your textsensor would get --:--
        -- moonrise
        moonriseHour, moonriseMinute = string.match(s, [["moonrise": {"hour":"(%d+)","minute":"(%d+)"]])
        if moonriseHour == nil then moonriseHour = '--' end
        if moonriseMinute == nil then moonriseMinute = '--' end
        if debug then print("Moonrise:\t"..moonriseHour..":"..moonriseMinute) end
        -- moonset
        moonsetHour, moonsetMinute = string.match(s, [["moonset": {"hour":"(%d+)","minute":"(%d+)"]])
        if moonsetHour == nil then moonsetHour = "--" end
        if moonsetMinute == nil then moonsetMinute = "--" end
        if debug then print("Moonset:\t"..moonsetHour..":"..moonsetMinute) end
Updated Wiki also....
Hardware:
Jmerino
Post by Jmerino »
I just installed the module and I'm doing something wrong because it doesn't show the picture.
It seems that the sensors and the lua script its working fine because all are filled correctly.
I modified the custom.js to include the module but nothing.
I need some help please
marxkemp
Post by marxkemp »
Same here. We must have done something wrong..
Verstuurd vanaf mijn SM-G930F met Tapatalk
Jmerino
Post by Jmerino »
Solved
marxkemp
Post by marxkemp »
What did you do?
Jmerino
Post by Jmerino »
My problem was here:
var _IDXmoonpicture = IDX_Number; //index of the uservariabele MoonPicture
I declared correctly in the code but after a deep revision of the code I detected another declaration in the vars at the beginning of code with 0 value.
Just change this idx with the correct one and delete the new var declared by myself.
Now here is new moon and only show a black circle but it seems will be ok.
marxkemp
Post by marxkemp »
Ah, yes. Found it.
We have a 5% moon today but i think the picture is wrong now (full black moon)..
jimicek
Post by jimicek »
I think there is an error in the moon script: "waardecheck" should be replaced by "is_waxing" to give the correct moon phase picture
jvanthof
Post by jvanthof »
The Moon Phase module is not showing the images of the moon... I think I have followed all the instructions to the letter. The /var/tmp/phases.tmp file is filled with info. The dummy devices and user variables get filled with information (e.g. the MoonPicture variable contains "moon.89.png") but on the dashticz website: nada...
When I inspect the elements using the developer tools of Safari, it looks like the image is not properly set in the DOM:
<div class="col-xs-12 transbg imgblock imgblock17610" data-id="buttons.UNKNOWN">
  <div class="col-xs-12">
    <div class="moon"></div>
  </div>
</div>
The "buttons.UNKNOWN" doesn't look right...
My CONFIG.js (I thinks there's a typo on the Wiki btw...) contains these lines:
buttons.moon = {width:12, isimage:true, refreshimage:60000, image:'moon'}
and
columns[1] = {}
columns[1]['blocks'] = ['garbage','s1',buttons.moon]
columns[1]['width'] = 5;
Anyone knows what I'm missing?
BTW, infinite credits to all that worked on Domoticz, Dashticz and plugins/addons... I bow to you all!!
CaesarPL
Post by CaesarPL »
Is
config['idx_moonpicture'] = 7;
properly set?
EdwinK
Post by EdwinK »
CaesarPL wrote: Tuesday 10 October 2017 8:46 Is
properly set?
Looks okay to me.
jvanthof
Post by jvanthof »
Found it!!
It seems the Wiki is slightly outdated:
does not work for me. Replacing it with
config['idx_moonpicture'] = 1;
did the trick!
PS. I updated the wiki page...
marxkemp
Post by marxkemp »
This is bugging me for some time. How do I show the Maanfase and Maanpercentage in the blocks beneath the moon image?
I guess its adding the IDX with a different icon?
htilburgs
Post by htilburgs »
jvanthof wrote: Wednesday 11 October 2017 14:13 Found it!!
did the trick!
Thnx for updating the wiki. Overlooked this one....
Hardware:
PeJeWe
Domoticz version: Latest
Post by PeJeWe »
Dus this module works without a Wunderground API key?
