Dashticz - Module Moonphases
- htilburgs
Hardware:
- htilburgs
Re: Dashticz - Module Moonphases
As of sometime today (don't know exactly when), I've an error:
When I check manualy, then I see that the Moonrise is missing.
Has this something to do with Wunderground not sending the correct information?
"moonrise": {
"hour":"",
"minute":""
Error: EventSystem: in /home/pi/domoticz/scripts/lua/check_time_moon.lua: /home/pi/domoticz/scripts/lua/check_time_moon.lua:62: attempt to concatenate global 'moonriseMinute' (a nil value)
"moonrise": {
"hour":"",
"minute":""
"response": {
"version":"0.1",
"termsofService":"http://www.wunderground.com/weather/api/d/terms.html",
"features": {
"astronomy": 1
},"moon_phase": {
"percentIlluminated":"47",
"ageOfMoon":"22",
"phaseofMoon":"Waning Gibbous",
"hemisphere":"North",
"current_time": {
"hour":"14",
"minute":"56"
"sunrise": {
"hour":"7",
"minute":"09"
"sunset": {
"hour":"19",
"minute":"56"
"moonrise": {
"hour":"",
"minute":""
"moonset": {
"hour":"15",
"minute":"24"
"sun_phase": {
"sunrise": {
"hour":"7",
"minute":"09"
"sunset": {
"hour":"19",
"minute":"56"
Hardware:
- htilburgs
Re: Dashticz - Module Moonphases - Empty Moonrise
Just found and article from Wunderground on https://apicommunity.wunderground.com/w ... g-sometime
moonrise: {
hour: "",
minute: ""
moonset: {
hour: "11",
minute: "46"
And now for the million dollar question "how can we solve this in the source, when this happens" ???This happens when a day does not have a moon rise. In this case, the moon rose yesterday.
Hardware:
- EdwinK
- Domoticz version: BETA
So ,that was the problem
- htilburgs
Yip, but now the solution....
Haven't found anything yet. I'm looking in the lua script, but nothing works (yet).
Maybe somebody has a great idea??
Hardware:
- htilburgs
Ok, with some help I've changed the part of the script. That should avoid giving an error and in your textsensor would get --:--
Updated Wiki also....
-- moonrise
moonriseHour, moonriseMinute = string.match(s, [["moonrise": {"hour":"(%d+)","minute":"(%d+)"]])
if moonriseHour == nil then moonriseHour = '--' end
if moonriseMinute == nil then moonriseMinute = '--' end
if debug then print("Moonrise:\t"..moonriseHour..":"..moonriseMinute) end
-- moonset
moonsetHour, moonsetMinute = string.match(s, [["moonset": {"hour":"(%d+)","minute":"(%d+)"]])
if moonsetHour == nil then moonsetHour = "--" end
if moonsetMinute == nil then moonsetMinute = "--" end
if debug then print("Moonset:\t"..moonsetHour..":"..moonsetMinute) end
Hardware:
I just installed the module and I'm doing something wrong because it doesn't show the picture.
It seems that the sensors and the lua script its working fine because all are filled correctly.
I modified the custom.js to include the module but nothing.
I need some help please
Same here. We must have done something wrong..
Verstuurd vanaf mijn SM-G930F met Tapatalk
What did you do?
My problem was here:
var _IDXmoonpicture = IDX_Number; //index of the uservariabele MoonPicture
I declared correctly in the code but after a deep revision of the code I detected another declaration in the vars at the beginning of code with 0 value.
Just change this idx with the correct one and delete the new var declared by myself.
Now here is new moon and only show a black circle but it seems will be ok.
Ah, yes. Found it.
We have a 5% moon today but i think the picture is wrong now (full black moon)..
I think there is an error in the moon script: "waardecheck" should be replaced by "is_waxing" to give the correct moon phase picture
The Moon Phase module is not showing the images of the moon... I think I have followed all the instructions to the letter. The /var/tmp/phases.tmp file is filled with info. The dummy devices and user variables get filled with information (e.g. the MoonPicture variable contains "moon.89.png") but on the dashticz website: nada...
When I inspect the elements using the developer tools of Safari, it looks like the image is not properly set in the DOM:
The "buttons.UNKNOWN" doesn't look right...
My CONFIG.js (I thinks there's a typo on the Wiki btw...) contains these lines:
and
Anyone knows what I'm missing?
BTW, infinite credits to all that worked on Domoticz, Dashticz and plugins/addons... I bow to you all!!
<div class="col-xs-12 transbg imgblock imgblock17610" data-id="buttons.UNKNOWN">
<div class="col-xs-12">
<div class="moon"></div>
</div>
</div>
buttons.moon = {width:12, isimage:true, refreshimage:60000, image:'moon'}
columns[1] = {}
columns[1]['blocks'] = ['garbage','s1',buttons.moon]
columns[1]['width'] = 5;
Is properly set?
config['idx_moonpicture'] = 7;
- EdwinK
Looks okay to me.CaesarPL wrote: ↑Tuesday 10 October 2017 8:46 Isproperly set?Code: Select all
Found it!!
It seems the Wiki is slightly outdated:
does not work for me. Replacing it with
did the trick!
PS. I updated the wiki page...
config['idx_moonpicture'] = 1;
This is bugging me for some time. How do I show the Maanfase and Maanpercentage in the blocks beneath the moon image?
I guess its adding the IDX with a different icon?
- htilburgs
Thnx for updating the wiki. Overlooked this one....jvanthof wrote: ↑Wednesday 11 October 2017 14:13 Found it!!
It seems the Wiki is slightly outdated:does not work for me. Replacing it withCode: Select all
did the trick!Code: Select all
Hardware:
- Domoticz version: Latest
Dus this module works without a Wunderground API key?
