Digoo DG-R8S 433MHz Hygrometer Thermometer
This sensor does not work with rfxcom 433E receiver.
https://www.banggood.com/Digoo-DG-R8S-4 ... 39603.html
b_weijenberg
- Target OS: -
Re: Digoo DG-R8S 433MHz Hygrometer Thermometer
Correct, this sensor is not listed in the RFXtrx User Guide as supported.
This banggood sensor is listed as supported:
https://www.banggood.com/433MHz-Wireles ... 65559.html
RFX-433, RFX-433EMC, RFX-868
I know have also those and they do work.
This one works with RFLink so I hope that they will be able to also added it into RFXtrx.
I have also purchased this one:
https://www.banggood.com/Digoo-DG-R8H-4 ... 78108.html
and will report back if it is working.
I prefer the one without lcd display.
- Westcott
I've got a Digoo TH8868 and a TH8888.
Very nice displays, but the remote sensors are not seen by RFlink nor RFX.
cobra045
- Domoticz version: 3.4834
For RFXcom 433E receiver use this
https://www.banggood.com/DANIU-433MHz-W ... 65559.html
With the results below
Yes we know that, but we are also testing some others models.
Would it be possible to change only the transmitter part and will it then work or not? Probably not?
pierre75
Hello
In my experience signal form is :
Header : 650ms high and 8000ms low
Body : a set of 36 bits
bit 0 : 650ms high and 2000ms low
bit 1 : 650ms high and 4000ms low
bit 0-13 : id (seems different for each sensor. When you press test, id send id+1. When you reset power, id can be different)
bit 14-15 : channel-1 (select)
bit 16-27 : temperature in degre (must be divide by 10. for exemple 298 = 29.8)
bit 28-35 : humidity (assume 10 seems = LL from panel)
I tested with esp/arduino code using attachInterrupt(digitalPinToInterrupt(D7), change_D7, CHANGE); and change_D7 custom function
Good luck
Good luck
Maikie
I can confirm that the DG-R8B sensor works now.
meps007
Hi Maikie, Could you tell me how you added the DG-R8B device?
