Broadlink SPS3 smart socket support?
Hesmink
Hi All,
I just ordered a Broadlink sps3 smart socket with powermonitoring from aliexpress.
It's the cheapest 16A supporting socket with power monitoring I ever found (€ 18,95, free shipping).
Does anybody already put one of these in Domoticz?
Should't be that hard, I found a python library supporting it: https://github.com/mjg59/python-broadlink
Hesmink
Re: Broadlink SPS3 smart socket support?
Received it, and it works!
I can switch it on/off using python, and read the power value.
I'm going to use it for my dryer with the 'washing cycle' script.
aDJa
- Domoticz version: 4.9700
hi there Hesmink,
This sounds like great project with the budget power monitor from Broadlink. I also ordered it already.
Perhaps you can tell us more how you managed to get the values in Domoticz with Python?
OS: RPi4B, GH
ELECTRICITY: P1 Smart Meter USB
WATER: NPN inductive sensor
SOLAR: Omnik Inverter, PVOutput
LIGHTS: Philips HUE + GLEDOPTO + Yeelight
SENSORS: Xiaomi Temp + Humidity + Baro + Motion + HUE
tontze
- Domoticz version: Beta Ch
I would keep close eye on that "16A" socket ..
Smartthings
zigbee2mqtt
RFLink 433mhz / Nrf 2.4Ghz
Mi Light
esp8266MiLight Hub
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
woody4165
HiHesmink wrote: Monday 04 September 2017 23:48 Received it, and it works!
I just downloaded the script, but I haven't understood how it works.
Do I need to execute the setup.py with SSID, pwd and NetType?
I have already configured the SP3S with the E-control App.
- Phantom
- Domoticz version: 4.11652
Hey, there is also a wiki about this plugin: http://www.domoticz.com/wiki/Plugins/Br ... nformation
woody4165
Thanks, I thought it was different than the RM2 plugin.Phantom wrote:Hey, there is also a wiki about this plugin: http://www.domoticz.com/wiki/Plugins/Br ... nformation
I will check the wiki.
woody4165
Sorry for double consecutive post.
In the wiki I haven't found any info regarding controlling SP3 socket, but only RM2.
In any case I have created an Hardware in Domoticz like this, with IP and Mac of the SP3
and as result I've got these devices
I don't see anything related to power socket.
I get an error in the log related to ini file
But I don't know if has any effect for the SP3 use, if possible.
My SP3 is the S version where it can checked also power consumption.
2017-11-23 12:51:36.637 Error: (Broadlink SP3) ini file not found: /home/xxx/domoticz/plugins/BroadlinkRM2/BroadlinkRM2-37-254.ini
zak45
- Domoticz version: V2024.4
Actual plugin (v3) only manage RM2 device.
V4 will manage sp1/sp2/sp3/sp3s/a1/mp1
woody4165
If you need any testing, I will be glad.
Hesmink
I used the code from the link I posted, but with the modifications of this user: https://github.com/mjg59/python-broadlink/pulls/eschavaaDJa wrote: Saturday 04 November 2017 0:35 hi there Hesmink,
Haven't put the value back in domoticz, but I was planning to use the same scripts/method as for the TPLink HS110
Hesmink
Why is that?
tontze
Build quality and component quality on these chinese devices .. They tend to promise anything for sale
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
doh
Hi,Hesmink wrote: Monday 04 September 2017 23:48 Received it, and it works!
I have a similar device (Broadlink SC1).
I can see it when I do a discover/locate, but how to you "learn" to turn these devices on and off?
doh
I managed to get these working. I found a script calls sp2.py which does the job perfectly:
https://github.com/NightRang3r/Broadlink-NodeSP2
Hi!
Please advise how to manage Broadlink SP3 from a computer running Ubuntu.
I just need to turn the socket on and off.
Preferably in a bash script.
Or Python.
Or Python.
zak45,
thank you!
thank you!
