Broadlink SPS3 smart socket support?
Hesmink
Post by Hesmink »
Hi All,
I just ordered a Broadlink sps3 smart socket with powermonitoring from aliexpress.
It's the cheapest 16A supporting socket with power monitoring I ever found (€ 18,95, free shipping).
Does anybody already put one of these in Domoticz?
Should't be that hard, I found a python library supporting it: https://github.com/mjg59/python-broadlink
Hesmink
Re: Broadlink SPS3 smart socket support?
Post by Hesmink »
Received it, and it works!
I can switch it on/off using python, and read the power value.
I'm going to use it for my dryer with the 'washing cycle' script.
aDJa
Domoticz version: 4.9700
Post by aDJa »
hi there Hesmink,
This sounds like great project with the budget power monitor from Broadlink. I also ordered it already.
Perhaps you can tell us more how you managed to get the values in Domoticz with Python?
OS: RPi4B, GH
ELECTRICITY: P1 Smart Meter USB
WATER: NPN inductive sensor
SOLAR: Omnik Inverter, PVOutput
LIGHTS: Philips HUE + GLEDOPTO + Yeelight
SENSORS: Xiaomi Temp + Humidity + Baro + Motion + HUE
tontze
Domoticz version: Beta Ch
Post by tontze »
I would keep close eye on that "16A" socket ..
Smartthings
zigbee2mqtt
RFLink 433mhz / Nrf 2.4Ghz
Mi Light
esp8266MiLight Hub
woody4165
Post by woody4165 »
Hesmink wrote: Monday 04 September 2017 23:48 Received it, and it works!
I just downloaded the script, but I haven't understood how it works.
Do I need to execute the setup.py with SSID, pwd and NetType?
I have already configured the SP3S with the E-control App.
Phantom
Domoticz version: 4.11652
Post by Phantom »
Hey, there is also a wiki about this plugin: http://www.domoticz.com/wiki/Plugins/Br ... nformation
woody4165
Post by woody4165 »
Phantom wrote:Hey, there is also a wiki about this plugin: http://www.domoticz.com/wiki/Plugins/Br ... nformation
Thanks, I thought it was different than the RM2 plugin.
I will check the wiki.
woody4165
Post by woody4165 »
Sorry for double consecutive post.
In the wiki I haven't found any info regarding controlling SP3 socket, but only RM2.
In any case I have created an Hardware in Domoticz like this, with IP and Mac of the SP3
and as result I've got these devices
I don't see anything related to power socket.
I get an error in the log related to ini file
2017-11-23 12:51:36.637 Error: (Broadlink SP3) ini file not found: /home/xxx/domoticz/plugins/BroadlinkRM2/BroadlinkRM2-37-254.ini
But I don't know if has any effect for the SP3 use, if possible.
My SP3 is the S version where it can checked also power consumption.
zak45
Domoticz version: V2024.4
Post by zak45 »
Actual plugin (v3) only manage RM2 device.
V4 will manage sp1/sp2/sp3/sp3s/a1/mp1
woody4165
Post by woody4165 »
If you need any testing, I will be glad.
Hesmink
Post by Hesmink »
aDJa wrote: Saturday 04 November 2017 0:35 hi there Hesmink,
I used the code from the link I posted, but with the modifications of this user: https://github.com/mjg59/python-broadlink/pulls/eschava
Haven't put the value back in domoticz, but I was planning to use the same scripts/method as for the TPLink HS110
Hesmink
Post by Hesmink »
tontze wrote: Saturday 04 November 2017 11:46 I would keep close eye on that "16A" socket ..
Why is that?
tontze
Post by tontze »
Hesmink wrote: Friday 24 November 2017 21:59
Why is that?
Build quality and component quality on these chinese devices .. They tend to promise anything for sale :) Might be ok device thought if you just dont control your sauna, or such, with it :D
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
doh
Post by doh »
I have a similar device (Broadlink SC1).
I can see it when I do a discover/locate, but how to you "learn" to turn these devices on and off?
doh
Post by doh »
I managed to get these working. I found a script calls sp2.py which does the job perfectly:
https://github.com/NightRang3r/Broadlink-NodeSP2
uname
Post by uname »
Hi!
Please advise how to manage Broadlink SP3 from a computer running Ubuntu.
I just need to turn the socket on and off.
Preferably in a bash script.
Or Python.
zak45
Post by zak45 »
uname
Post by uname »
zak45,
thank you!
