LUA Script: Time how much a device is ON
ycahome
Domoticz version: lat Beta
Post by ycahome »
Hi there,
just finished the first version of the "script_time_switch-timer" LUA script.
Its a modified version of "Time Script to Turn a Light Off"
on "https://www.domoticz.com/wiki/Smart_Lua_Script"
With this script:
if you create a "General, Counter incremental" with a name of a switch prefixed by " (TMR)" this will count
when your switch is ON.
Domoticz Installation instructions:
- Save this script as "script_time_switch-timer.lua" on "Domoticz/scripts/lua" folder
- Add a new "General, Counter incremental" with a name of a switch prefixed by " (TMR)" for each switch you want to time.
example:
Timed switch:
Timer device:
Hope you like it!!
--   Switch Timer for Domoticz via LUA Script
--   Ycahome, 2017
--   https://www.domoticz.com/forum
function timedifference(s)
   year = string.sub(s, 1, 4)
   month = string.sub(s, 6, 7)
   day = string.sub(s, 9, 10)
   hour = string.sub(s, 12, 13)
   t1 = os.time()
   return difference
function trim1(s)
  return (s:gsub("^%s*(.-)%s*$", "%1"))
debuglevel = 0
local function update(idx, value1, value2)
    local cmd = idx.."|"..value1.."|"..value2
    --local cmd = string.format("%d|0|%f;%f", idx, value1, value2)
    table.insert (commandArray, { ['UpdateDevice'] = cmd } )
for i, v in pairs(otherdevices) do
   timeon = 240
   tc = tostring(i)
   --v = i:sub(1,4)
   v = string.sub(i, -5)
   if (v == '(TMR)') then
     if (debuglevel > 0) then print("Timer Device Detected:".. i) end
     tc2 = string.len(i)
     --print("Len:".. tc2)
     vname = trim1(tostring(string.sub(i,1,tc2-5)))
     if (otherdevices[vname] == 'On') then
        if (debuglevel > 0) then print("Timed Device:".. vname) end
        print("Timed Device Detected ON:" ..vname)
        if (debuglevel > 0) then print("Timer Dev Idx:".. otherdevices_idx[i]) end
        if (debuglevel > 0) then print("Timed Dev Idx:".. otherdevices_idx[vname]) end
        if (debuglevel > 0) then print("Current Value:".. otherdevices[i]) end
        newvalue = otherdevices[i] + 1
        --newvalue = 1
        if (debuglevel > 0) then print("New Value:".. newvalue) end
        --commandArray['UpdateDevice'] = otherdevices_idx[i]..'|1|'..newvalue
        update (otherdevices_idx[i], 1, newvalue)
   if (v == 'PIR----') then
      difference = timedifference(otherdevices_lastupdate[tc])
      if (difference > timeon and difference < (timeon + 60)) then
         tempdiff = tostring(difference)
         c = i:sub(4)
         tempmessage = c.." Light Off - after at least " .. (timeon+1) .. "secs up - actually - " .. tempdiff .. "seconds"
         print(tempmessage)
         commandArray[c] = 'Off'
Wob76
Re: LUA Script: Time how much a device is ON
Post by Wob76 »
Thanks for the script, I thought i would give it a try, but think I am missing something, it is counting way to fast.
Does it only count from the time you start running it or does it do a count back using the logs?
I created a dummy incremental counter, the Type is set to count, the Offset 0 and I entered Time if Quantity and mins in Value Unit.
Thanks,
Wob
ycahome
Post by ycahome »
Hello Wob76.
LUA scripts executed every minute on Domoticz. So, this script just perform the calculations (discovering "(TMR)" devices and their counterparts)
and increasing "*(TMR)" value by 1.
In fact, starts to count as soon as run it.
Your counter (from what you said) seems correct. Be sure to name this device correctly <name of switch>+"(TMR)".
Wob76
Post by Wob76 »
Thanks for the reply.
It seems to match up fine, I can see it detected in the log, but after about 60mins from install my counter is showing 249mims, the switch has been on only about 3 hours all day, any idea why it would count to much?
Thanks,
Wob
Sent from my SM-G935F using Tapatalk
ycahome
Post by ycahome »
i don't know if its a Domoticz version difference (my Version: 3.8153) or something else.
my log clearly display firings every 1min:
2017-08-17 13:01:03.504 EventSystem: Script event triggered: /home/yiannis/domoticz/scripts/lua/script_time_switch-timer.lua
2017-08-17 13:02:03.102 EventSystem: Script event triggered: /home/yiannis/domoticz/scripts/lua/script_time_switch-timer.lua
2017-08-17 13:03:03.221 EventSystem: Script event triggered: /home/yiannis/domoticz/scripts/lua/script_time_switch-timer.lua
can you give more details from your setup?
Nautilus
Post by Nautilus »
Sounds like a classic case of defining the script as "device" or "all" type of script (triggering at any device change) when in fact it should be set as time script (runs only once a minute). Hope this helps...:)
Wob76
Post by Wob76 »
Nautilus wrote: Thursday 17 August 2017 23:55 Sounds like a classic case of defining the script as "device" or "all" type of script (triggering at any device change) when in fact it should be set as time script (runs only once a minute). Hope this helps...:)
You are on the money, I haven't actually used any lua scripts (I have been using dzVents), and I had saved it using the Events interface (default is all).
Now if I change it to "Time" nothing at all happens.
So I went back and followed the instructions and manually saved the script as domoticz/scripts/lua/script_time_switch-timer.lua. But it still doesn't trigger.
I have also restarted Domoticz, what am I missing? My dzVents scripts are firing as expected.
Thanks,
Wob
Wob76
Post by Wob76 »
OK, I enabled debugging in the script and I can see it firing, but it is only detecting the switch, it is not counting it as on.
2017-08-18 09:15:00.032 LUA: Timer Device Detected:Test Switch (TMR)
2017-08-18 09:16:00.041 LUA: Timer Device Detected:Test Switch (TMR)
I am running Domoticz Version: 3.8280
Wob76
Post by Wob76 »
OK, I added a second timer device for my AC, the unit I actually want to monitor, and the Test Switch started to work, seems to be counting properly now. Just need to wait for the AC to be used :)
Edit: I just set a scene to turn the AC on for 2 min, script counted 1 min, but I think that was prob just timing of the script, so I am calling it working.
Edit2: My partner used the AC today, and time shown on the counter matches up with the logs of the switch, so all good.
Thanks for the help.
Wob
ycahome
Post by ycahome »
Glad to hear that this worked for you.
This script is a workaround for a feature that is missing from the core of Domoticz.
This timer has a big problem. If a switch turned on at "10:01" and off at "10:59" nothing will be recorded (58 seconds lost from counter).
Am checking if this can be implemented with "OnAction" and "OffAction" scripts. But -for now- ,current functionality, seems enough.
Wob76
Post by Wob76 »
It does seem like something that could be introduced at the core, the system records timestamps for on off, so wouldn't be to hard to include running time stats. This seems good enough for my needs, but I'll be interested in how you go.
Wob
JanAtHome
Domoticz version: 38153
Post by JanAtHome »
Verry useful, works fine
heistje
Domoticz version: 2023.2
Post by heistje »
Hi guys,
thank you for this script, works rather good but when I try to use the value of the incremental counter I get the total incremental value (total of all days, not of today).
I would like to work with the total of today... is this possible? How?
I'm using following syntax:
tonumber(otherdevices["Zwembad filterpomp (TMR)"])
where "Zwembad filterpomp" is the device from what I would like to know how long it was "ON" today..
but it returns, as already said, the total of all days.
Thx for your help
Bullseye on RPI 4
Aeotec Z-Wave Plus Z-Stick Gen5
Zwave-JS-UI
RFXtrx433E
Eth8020
P1 USB
Shellys
ESP8266
mvzut
Post by mvzut »
This has always been the behavior of counters in Domoticz. It shows the daily increment in the dashboard, but I have never found a way to retrieve this number from the device in LUA.
I ended up maintaining the daily status in a separate device, I used a dummy device of the type "Custom Sensor" for this. I increase the value of this sensor every minute that the corresponding device is on (just like the total counter), and I set it back to 0 every night at 0:00h using a timer script.
EricT
Domoticz version: 3.9440
Post by EricT »
by mvzut » Sunday 17 June 2018 23:13
Same here, have been searching for it and couldn't find it either. :(
mvzut,
Can you share that script here please?
Thanks,
Eric
if it was easy everybody would do it
mvzut
Post by mvzut »
EricT wrote:mvzut,
Thanks,
Eric
Sure!
To read & update the two devices shown in my post above, I use the following code in a time-based lua script:
 -- Update PC Niels timer
TotalMinutesOn = otherdevices_svalues['PC Niels timer']
TodayMinutesOn = otherdevices_svalues['PC Niels vandaag']
if otherdevices['PC Niels'] == 'On' then
  TotalMinutesOn = TotalMinutesOn + 1
  TodayMinutesOn = TodayMinutesOn + 1
table.insert(commandArray, {['UpdateDevice'] = otherdevices_idx['PC Niels timer'] .. '|0|' .. TotalMinutesOn})
table.insert(commandArray, {['UpdateDevice'] = otherdevices_idx['PC Niels vandaag'] .. '|0|' .. TodayMinutesOn})
To reset the value of the day timer every night I use the following code (also in a time-based script):
Time = os.date("%H:%M")
if Time == '00:00' then
  table.insert(commandArray, {['UpdateDevice'] = otherdevices_idx['PC Niels vandaag'] .. '|0|0'})
You may have to rewrite things a bit to make it compliant with the script suggested by the OP.
EricT
Post by EricT »
Hi mvzut,
Exellent, thank you very much! :D
Eric
Ray-Man
Domoticz version: 2021.1
Post by Ray-Man »
Just a minor thing if you also want to time dimmers:
change
to
if (otherdevices[vname] ~= 'Off') then
Obvious to most I guess, but if you're not into LUA it might help....
Just my to cents.......
gajotnt
Domoticz version: V4.9700
Post by gajotnt »
Using this script to easilly know how much time my pool pump has been runing for each day, but havent figured out how to set it up to send me a message when it has reach a certain time, have tried several ways none of it works on this dummy device.
tried with just 130, with 130 minutes, the type tried Today, tried Update.
And yes i have notifications working on other switches/counters
hemant5400z
Post by hemant5400z »
I'm trying to use this timer function with version 4.10265, but cannot seem to get is working.
I have:
1 switch called test; light/switch, Switch, on/off
1 utility called test (TMR), General, Counter Incremental, type is Time, counter divider 0, Meter Offset 0
I can see the event triggered in the log but the utility shows a "?" and keeps at 0. When i change the utility to counter instead of time I do see increase of the number but no time is showing just an integer.
Anyone who is able t help?
Cheers,
Hemant
