Duplicate Z-Wave ID (bug?)
bluedog
Post by bluedog »
I included two new Aeotec Z-Wave bulbs to my network.
The second bulb has been given the same ID as the first bulb. Is that a bug?
It doesn't appear in the devices list either, so I can't use it. I've tried removing it and re-adding it, but it gets given the same ID each time.
Any ideas?
duplicate IDs.PNG (19.45 KiB) Viewed 1776 times
tlpeter
Re: Duplicate Z-Wave ID (bug?)
Post by tlpeter »
It is about the nodeID, the manufactor is the same as it is the same type of device so this is normal.
I have the same ID for multiple devices of the same type.
bluedog
Post by bluedog »
Ah, that's good to know. In that case, the problem is that I just can't see the second globe in Domoticz. I can see it in OpenHAB, so I know it works. (I just tried OpenHAB to see if it works - I'm not running any other system in parallel or anything like that).
tlpeter
Post by tlpeter »
Try excluding it and include it again.
Open a second webinterface and look in the log while including it.
bluedog
Post by bluedog »
Nothing stands out in the log...
2017-08-12 16:28:20.207 New sensors allowed for 5 minutes...
2017-08-12 16:28:20.207 OpenZWave: Node Include command initiated...
2017-08-12 16:28:38.842 OpenZWave: Node Removed. HomeID: 3235667781, NodeID: 7 (0x07)
2017-08-12 16:28:38.868 OpenZWave: New Node added. HomeID: 3235667781, NodeID: 7 (0x07)
2017-08-12 16:28:38.868 OpenZWave: Value_Added: Node: 7 (0x07), CommandClass: SWITCH MULTILEVEL, Label: Level, Instance: 1
2017-08-12 16:28:38.868 OpenZWave: Value_Added: Node: 7 (0x07), CommandClass: SWITCH MULTILEVEL, Label: Bright, Instance: 1
2017-08-12 16:28:38.868 OpenZWave: Value_Added: Node: 7 (0x07), CommandClass: SWITCH MULTILEVEL, Label: Dim, Instance: 1
2017-08-12 16:28:39.098 OpenZWave: Value_Added: Node: 7 (0x07), CommandClass: COLOR, Label: Color, Instance: 1
2017-08-12 16:28:39.098 OpenZWave: Value_Added: Node: 7 (0x07), CommandClass: COLOR, Label: Color Index, Instance: 1
2017-08-12 16:28:40.903 (Hub1) Light/Switch (Level)
bluedog
Post by bluedog »
I seemed to have built up a collection of unused RGBW devices. Deleted them. I can use the new light now.
