MiLight Red-Green weakness
He Forum,
if i change the color of my milight-Devices to red, the color is changed to green and otherwhise its the same. I think my NRF24L01 has some problems to deal with red and green.
Any Ideas how to solfe this?
I´m using the R46 Firmware witht the Domoticz Beta Branch.
greetz
THPS
greetz
THPS
Re: MiLight Red-Green weakness
I've got the same problem running the latest stable version (3.8153) with RFlink R47 firmware.
Any help would be much appreciated.
- Stuntteam
We are checking the Domoticz part of the code..
I found the following on github.
https://github.com/domoticz/domoticz/pull/1366
It is not clear to me if and which lines have to be changed in the latest version.
- Domoticz version: 2024.4
Any news on this? Same problem here with MiLight Led lamps.
Running on version v3.8423
- Domoticz version: 3.8993
How do you use the R47 Firmware with DOmoticz and Milight? I have add my Wifi iBox inside Domoticz and use it with that.
Is it possible to pair them now directly inside domoticz?
I control them directly from my rflink with the NRF24L01. I can pair them, but as stated earlier the red and green colours are switched when using the colour slider in domoticz.
this line is added: int iHue = ((255 - pLed->value) + 108) & 0xFF;
and still is in today's code i think the +108 needs correcting so that red and green are good
I have this issue too
- Stuntteam
Should be solved for Milight RGBW in the next beta version.
Also corrected for other milight types..but you might need r48 (available soon)
I alsof conform this is working as expected.
Thanks for the fix
Thanks for the fix
This is still a problem but for me for the Fibaro RGBW module.
If i select green then i get red and otherwise.
Is this system wide or per protocol?
- Stuntteam
Per protocol.. and it has been fixed for RFlink..
