MiLight Red-Green weakness
thps
He Forum,
if i change the color of my milight-Devices to red, the color is changed to green and otherwhise its the same. I think my NRF24L01 has some problems to deal with red and green.
Any Ideas how to solfe this?
I´m using the R46 Firmware witht the Domoticz Beta Branch.
greetz
THPS
greetz
THPS
sebvi
Re: MiLight Red-Green weakness
I've got the same problem running the latest stable version (3.8153) with RFlink R47 firmware.
Any help would be much appreciated.
- Stuntteam
We are checking the Domoticz part of the code..
sebvi
I found the following on github.
https://github.com/domoticz/domoticz/pull/1366
It is not clear to me if and which lines have to be changed in the latest version.
Milifax
- Domoticz version: 2024.4
Any news on this? Same problem here with MiLight Led lamps.
Running on version v3.8423
poudenes
- Domoticz version: 3.8993
How do you use the R47 Firmware with DOmoticz and Milight? I have add my Wifi iBox inside Domoticz and use it with that.sebvi wrote: Saturday 16 September 2017 23:51 I've got the same problem running the latest stable version (3.8153) with RFlink R47 firmware.
Is it possible to pair them now directly inside domoticz?
sebvi
I control them directly from my rflink with the NRF24L01. I can pair them, but as stated earlier the red and green colours are switched when using the colour slider in domoticz.
djjonesy
this line is added: int iHue = ((255 - pLed->value) + 108) & 0xFF;
and still is in today's code i think the +108 needs correcting so that red and green are good
donk7413
I have this issue too
- Stuntteam
Should be solved for Milight RGBW in the next beta version.
Also corrected for other milight types..but you might need r48 (available soon)
Milifax
Works with the latest beta! Great! Thanks!Stuntteam wrote: Monday 09 October 2017 23:02 Should be solved for Milight RGBW in the next beta version.
mosjonathan
I alsof conform this is working as expected.
Thanks for the fix
Thanks for the fix
tlpeter
This is still a problem but for me for the Fibaro RGBW module.
If i select green then i get red and otherwise.
Is this system wide or per protocol?
- Stuntteam
Per protocol.. and it has been fixed for RFlink..
