Dashticz - Function - Graphs
robgeerts
Domoticz version: 3.7067
Post by robgeerts »
Done some small changes to the graphs.
Could you test latest beta? Please report errors here.
If you encounter problems, please send me the output you get on:
http://[DOMOTICZ-URL]/json.htm?type=graph&sensor=counter&idx=[IDX]&range=[day,month,year]
blacksn0w
Re: Dashticz - Function - Graphs
Post by blacksn0w »
Now none of my graphs are working anymore :(.
I mean the ones if you click on a temperature block and the frame opens.
Neither after the frame is loaded nor when you click a button for the timeframe.
robgeerts
Post by robgeerts »
Do you get any errors?
blacksn0w
Post by blacksn0w »
No console errors so far, there seems to be a problem at line 253 of graph.js, typeof(data_com[0]) is always, for each graph, undefined, so the code will never go any further and create the morris area.
EdwinK
Post by EdwinK »
No error messages, but no graphs as well
robgeerts
Post by robgeerts »
Just pushed a new beta!
@EdKo66, could you test this one?
With @blacksn0w it is working now (thanks)
EdwinK
Post by EdwinK »
Yes, it's working again ;)
Onrust
Domoticz version: 4.10717
Post by Onrust »
Will test in the weekend. Yesterday my PI didn't boot anymore after a short power outage. :(
pmalvino
Post by pmalvino »
hello Rob. It's possible to do the selection of two values [idx_1] or [idx_2], like we do on the blocks.
I don't know if you remember , i made a request for this some time ago. Thank you
Onrust
Post by Onrust »
Onrust wrote:Will test in the weekend. Yesterday my PI didn't boot anymore after a short power outage. :(
Graphs are working correctly now! Many thanks!
Jonb
Domoticz version: 3.5877
Post by Jonb »
pmalvino wrote:hello Rob. It's possible to do the selection of two values [idx_1] or [idx_2], like we do on the blocks.
Does it work?
webrazor
Post by webrazor »
Hello Rob,
Is it possible to select how many points you want in a graph?
Because for the solar panels i have a point every hour and for the p1 energy usage every 5 min?
And both i like to change solar more points and p1 energie usage less point for a smoother graph.
jlites00
Post by jlites00 »
I'm wondering if the KWH logging graph could be setup differently. Is it possible to show weekly, monthly & yearly usage as a lump sum number as opposed to a graph? Anyone here knows of a plugin that does that?
Onrust
Post by Onrust »
Would be nice if you could select a period of time in the graph, and to see the total kWh's used in that selected period :)
stlaha2007
Post by stlaha2007 »
Running with the fixed graphs... working great...
However, the graphs from P1 Energy gathers the 5 minute data. It takes noticeble time when loading. And has some drawback on the responsiveness on my tablet.
I'm thinking of removing the P1 Energy graph from the mainscreen. Actually would hate it to remove.
How about the other graphs. Do they also have a drawback on memory/performance?
Is there a hidden option for config.js to disable All or per block there graph(s)?
Grtz...
Sent from my D6603 using Tapatalk
gielie
Domoticz version: latest β
Post by gielie »
Does anyone know how i change the hight of the graphs?
- Aeotec MultiSensor 6
- FIBARO FGS223
- FIBARO FGWPE Wall Plug
- Neo CoolCam Power plug
- Popp Smoke Detector
- Toon
- Kodi Media Server
edwin
Post by edwin »
@gielie: Try something like this in custom/custom.css:
#graphoutput34 {height: 120px;}
This should change the height of 'graph_34'.
Recent beta (git) on Arch Linux | Dashticz v2 (git) | RFLink 46.0 | Ikea Trådfri | P1 Smart Meter
gielie
Post by gielie »
edwin wrote: Thursday 10 August 2017 11:03 @gielie: Try something like this in custom/custom.css:
Thanks Edwin,
Works like a charm.
- FIBARO FGS223
- Toon
- Kodi Media Server
askmurphy
Post by askmurphy »
I am busy with my dashticz mainboard and graphs:
For example, I have now a graph displaying our SolarEdge kWh Meter.
I see a graph with 3 buttons on top: 'laatste uren', 'vandaag' and 'afgelopen maand'.
The graph 'laatste uren' is visable.
How can I show the graph 'vandaag' as the default instead of the graph 'visable' ?
Or is that not possible (yet)?
Great dashboard by the way, keep on the good work ;-)
dlefol
Post by dlefol »
You can use the option
config['standard_graph'] = 'hours';
to set the default graph to hours, days or month.
Hope this helps
