Dashticz - Function - Graphs
robgeerts
- Domoticz version: 3.7067
Done some small changes to the graphs.
Could you test latest beta? Please report errors here.
If you encounter problems, please send me the output you get on:
http://[DOMOTICZ-URL]/json.htm?type=graph&sensor=counter&idx=[IDX]&range=[day,month,year]
blacksn0w
Re: Dashticz - Function - Graphs
Now none of my graphs are working anymore
I mean the ones if you click on a temperature block and the frame opens.
Neither after the frame is loaded nor when you click a button for the timeframe.
robgeerts
Do you get any errors?
blacksn0w
No console errors so far, there seems to be a problem at line 253 of graph.js, typeof(data_com[0]) is always, for each graph, undefined, so the code will never go any further and create the morris area.
- EdwinK
- Domoticz version: BETA
No error messages, but no graphs as well
robgeerts
Just pushed a new beta!
@EdKo66, could you test this one?
With @blacksn0w it is working now (thanks)
- EdwinK
Yes, it's working again
Onrust
- Domoticz version: 4.10717
Will test in the weekend. Yesterday my PI didn't boot anymore after a short power outage.
pmalvino
hello Rob. It's possible to do the selection of two values [idx_1] or [idx_2], like we do on the blocks.
I don't know if you remember , i made a request for this some time ago. Thank you
Onrust
Graphs are working correctly now! Many thanks!Onrust wrote:Will test in the weekend. Yesterday my PI didn't boot anymore after a short power outage.
Jonb
- Domoticz version: 3.5877
Does it work?pmalvino wrote:hello Rob. It's possible to do the selection of two values [idx_1] or [idx_2], like we do on the blocks.
webrazor
Hello Rob,
Is it possible to select how many points you want in a graph?
Because for the solar panels i have a point every hour and for the p1 energy usage every 5 min?
And both i like to change solar more points and p1 energie usage less point for a smoother graph.
jlites00
I'm wondering if the KWH logging graph could be setup differently. Is it possible to show weekly, monthly & yearly usage as a lump sum number as opposed to a graph? Anyone here knows of a plugin that does that?
Onrust
Would be nice if you could select a period of time in the graph, and to see the total kWh's used in that selected period
stlaha2007
- Target OS: -
Running with the fixed graphs... working great...
However, the graphs from P1 Energy gathers the 5 minute data. It takes noticeble time when loading. And has some drawback on the responsiveness on my tablet.
I'm thinking of removing the P1 Energy graph from the mainscreen. Actually would hate it to remove.
How about the other graphs. Do they also have a drawback on memory/performance?
Is there a hidden option for config.js to disable All or per block there graph(s)?
Grtz...
Sent from my D6603 using Tapatalk
Grtz...
- gielie
- Domoticz version: latest β
Does anyone know how i change the hight of the graphs?
- Aeotec MultiSensor 6
- FIBARO FGS223
- FIBARO FGWPE Wall Plug
- Neo CoolCam Power plug
- Popp Smoke Detector
- Toon
- Kodi Media Server
- FIBARO FGS223
- Toon
- Kodi Media Server
edwin
@gielie: Try something like this in custom/custom.css:
This should change the height of 'graph_34'.
#graphoutput34 {height: 120px;}Recent beta (git) on Arch Linux | Dashticz v2 (git) | RFLink 46.0 | Ikea Trådfri | P1 Smart Meter
- gielie
Thanks Edwin,edwin wrote: Thursday 10 August 2017 11:03 @gielie: Try something like this in custom/custom.css:
This should change the height of 'graph_34'.Code: Select all
Works like a charm.
- FIBARO FGS223
- Toon
- Kodi Media Server
- FIBARO FGS223
- Toon
- Kodi Media Server
askmurphy
I am busy with my dashticz mainboard and graphs:
For example, I have now a graph displaying our SolarEdge kWh Meter.
I see a graph with 3 buttons on top: 'laatste uren', 'vandaag' and 'afgelopen maand'.
The graph 'laatste uren' is visable.
How can I show the graph 'vandaag' as the default instead of the graph 'visable' ?
Or is that not possible (yet)?
Great dashboard by the way, keep on the good work
dlefol
You can use the optionto set the default graph to hours, days or month.
Hope this helps
config['standard_graph'] = 'hours'; Hope this helps
