Dashticz - Module - Topbar
robgeerts
Domoticz version: 3.7067
Post by robgeerts »
Added a topbar! Not only to give the dashboard more 'body' but also to add some new functions like a settings-icon (not working yet). And maybe in the future things like notifications and stuff.
To disable, add in config.js:
var _HIDE_TOPBAR			= false;
To change, add in config.js:
var columns = {}
columns['bar'] = {}
columns['bar']['blocks'] = ['logo','settings']
blacksn0w
Re: Dashticz - Module - Topbar
Post by blacksn0w »
Great feature! The "Dashticz" text is hardcoded in main.js, right? It might be cooler to edit this respectively make it editable.
EDIT: And maybe editable background transparency, this is editable via custom.css, but would be easier in custom.js itself.
robgeerts
Post by robgeerts »
Title can be changed in latest beta, add in config.js:
var _APP_TITLE = 'My Title';
EdwinK
Post by EdwinK »
I liked the idea. Unfortunately, my screensize is too small, so everything was pushed a little to far down, so the bottom row wasn't visible anymore.
Teunissm
Domoticz version: V3.5858
Post by Teunissm »
Is it also possible to make the topbar more transparent and make de borders a less smaller? Maybe in the config_css?
robgeerts
Post by robgeerts »
Add this to custom.css:
.transbg.dark.col-xs-1, .transbg.dark.col-xs-2, .transbg.dark.col-xs-3, .transbg.dark.col-xs-4, .transbg.dark.col-xs-5, .transbg.dark.col-xs-6, .transbg.dark.col-xs-7, .transbg.dark.col-xs-8, .transbg.dark.col-xs-9, .transbg.dark.col-xs-10, .transbg.dark.col-xs-11, .transbg.dark.col-xs-12 {
    border: 7px solid rgba(255,255,255,0);
    background: rgba(0,0,0,0.5);
    background-clip: padding-box;
Change, for example:
TO
background: rgba(0,0,0,0.1);
And/or add this to custom.css:
.colbar.transbg {
    padding-left: 1px !important;
    padding-right: 1px !important;
    padding-top: 2px !important;
    padding-bottom: 2px !important;
Teunissm
Post by Teunissm »
the first one indeed did the trick. now i have al the blocks and the topbar the same
thanx.
johansson
Post by johansson »
I accidentally the whole topbar, is this bad?
While fiddling with settings I switched off the topbar and cannot get it switched back on, which means the settings-button is gone as well. I must admit I didn't get the local settings/config.js -thing at all, i.e seems that settings in config.js (with capitals) make no difference in the web interface. How should the config.js be used in order to see the changes in the dashboard?
e. Solved: obviously a minute after posting came across the solution :D Didn't notice the config.js was by default completely commented out...
gielie
Domoticz version: latest β
Post by gielie »
I really like the topbar but my day name is in english and id like to have it in Dutch, how can i do this?
I also like to remove the time from the topbar, so only the date, is this possible?
- Aeotec MultiSensor 6
- FIBARO FGS223
- FIBARO FGWPE Wall Plug
- Neo CoolCam Power plug
- Popp Smoke Detector
- Toon
- Kodi Media Server
EdwinK
Post by EdwinK »
Set language to NL if you want it in Dutch. Not sure how to change the time setting
gielie
Post by gielie »
EdwinK wrote: Monday 20 November 2017 15:45 Set language to NL if you want it in Dutch. Not sure how to change the time setting
i have it set to nl_NL but this doesn't change it
- FIBARO FGS223
- Toon
- Kodi Media Server
aiolos
Domoticz version: stable
Post by aiolos »
gielie wrote: Monday 20 November 2017 15:46
the language can be in the local storage of the browser, maybe you need to clear that.
In the config you can also change the following setting, causing all clock block show no time at all:
config['shorttime'] = ' ';
(note the space, an empty string would cause a very long date/time string)
Contributor to Dashticz
More on my Github profile
htilburgs
Post by htilburgs »
gielie wrote: Monday 20 November 2017 15:34 I really like the topbar but my day name is in english and id like to have it in Dutch, how can i do this?
The topbar is built up in parts, which you can define in config.JS
columns['bar'] = {}
You can leave out 'miniclock', then there is no clock, but it's not nice alligned, because setup / fullscreen is not on the right.
A 'dirty' workaround for this:
- Create a dummy switch and take note of the IDX
- Create an entry in config.JS for the dummy switch
blocks[IDX] = {} //Dummy block for topbar
blocks[IDX]['title'] = ''
blocks[IDX]['icon'] = '';
blocks[IDX]['hide_data'] = true;
blocks[IDX]['protected'] = true;
blocks[IDX]['width'] = 8;
- Create an entry in custom.css
/* Dummy for Topbar */
.block_440 {
	height:0px !important;
	background-color: rgba(0,0,0,0) !important;
- Make topbar in config.JS like this
columns['bar'] = {}
columns['bar']['blocks'] = ['logo',440,'settings']
Maybe there is a nicer way, but this is how it can be done. Maybe you'll have to play with blocks[IDX]['width'] = 8 but this works for me.... ;)
Hardware:
Derik
Post by Derik »
Dear All:
i post on the "wrong topic"
Is there perhaps someone that create a sort of css for the topbar:
https://www.domoticz.com/forum/viewtopi ... 40#p164127
Now it is to high..[ for my opinion ]
And the space should be used much beter.
