timer- variable dependancy
krommetje3108
Domoticz version: 3.5877
Post by krommetje3108 »
If possible I would like to have a timer that checks if a variable is a 0 or 1. That way I can program several timers for e.g. hollidays
e.g: a schoolholiday the var vacation is set to 1
not a schoolvacation the var vacation is set to 0
So can make timers that check the var and act accordingly....
D'rMorris
Re: timer- variable dependancy
Post by D'rMorris »
Did you read the wiki?
If you define a user variable called "vacation", you can use that in a script / blockly. You can either directly call the uservariable in a script like so:
 if ( uservariables["vacation"] == "1" ) then .....
I always put the uservariables in local script variables, this makes the code more readable and easier to debug imho.
In a script you would first fill a script variable based on the user variable like:
vacation = uservariables["vacation"]
Then you can just do:
 if (vacation == "1") then .....
