If possible I would like to have a timer that checks if a variable is a 0 or 1. That way I can program several timers for e.g. hollidays
e.g: a schoolholiday the var vacation is set to 1
not a schoolvacation the var vacation is set to 0
So can make timers that check the var and act accordingly....
timer- variable dependancy
krommetje3108
- Domoticz version: 3.5877
D'rMorris
Re: timer- variable dependancy
Did you read the wiki?
If you define a user variable called "vacation", you can use that in a script / blockly. You can either directly call the uservariable in a script like so:
I always put the uservariables in local script variables, this makes the code more readable and easier to debug imho.
In a script you would first fill a script variable based on the user variable like:
vacation = uservariables["vacation"]
Then you can just do:
if ( uservariables["vacation"] == "1" ) then .....In a script you would first fill a script variable based on the user variable like:
if (vacation == "1") then .....Who is online
