Pushover Error: Notification sent (pushover) => Failed Topic is solved
dressie
Domoticz version: V2020.2
Post by dressie »
I have noticed I'm not receiving any Pushover messages anymore. I'm running BETA V3.7972 on my main machine and V3.5980 on my other machine. The main machine gives the following error:
2017-06-14 09:20:58.087 Error: Pushover:
2017-06-14 09:20:58.087 Error: Notification sent (pushover) => Failed
On the other Domoticz system there's no error and pushover messages arrive at my phones.
I checked firewall settings, checked the API and still no results.
Does anyone else have the same issues? Looks like it stopped a week ago, perhaps with a certain BETA version?
All ideas are welcome!!
gennapium
Domoticz version: Stable
Re: Pushover Error: Notification sent (pushover) => Failed
Post by gennapium »
I am also running the latest Beta,but Pushover is working fine here when i use the test button. Did not test it with a script.
Ubuntu server, Raspberry Pi, PiFace 2, RFXCom, Z-wave Stick, Kaku, Sensor
dressie
Post by dressie »
I went back to stable and it works again! Also Pushbullet didn't work on beta. Something must go wrong. Only on Windows.
jvandenbroek
Post by jvandenbroek »
This would indicate that the server can't​be verified correctly. Beta contains an extra security check on the called URL.
Do you get a certificate error when opening https://api.pushover.net in Internet Explorer/Edge? If that's the case, something is wrong with the certificate store on your Windows installation.
Edit: Tested it on my Windows 10 installation and got the same problem. Created a pull request to fix this: https://github.com/domoticz/domoticz/pull/1637
Verstuurd vanaf mijn SM-N930F met Tapatalk
dressie
Post by dressie »
jvandenbroek wrote:This would indicate that the server can't​be verified correctly. Beta contains an extra security check on the called URL.
Thanks! Glad I'm not losing my mind ;)
