I have noticed I'm not receiving any Pushover messages anymore. I'm running BETA V3.7972 on my main machine and V3.5980 on my other machine. The main machine gives the following error:
2017-06-14 09:20:58.087 Error: Pushover:
2017-06-14 09:20:58.087 Error: Notification sent (pushover) => Failed
On the other Domoticz system there's no error and pushover messages arrive at my phones.
I checked firewall settings, checked the API and still no results.
Does anyone else have the same issues? Looks like it stopped a week ago, perhaps with a certain BETA version?
All ideas are welcome!!
Pushover Error: Notification sent (pushover) => Failed Topic is solved
gennapium
- Domoticz version: Stable
Re: Pushover Error: Notification sent (pushover) => Failed
I am also running the latest Beta,but Pushover is working fine here when i use the test button. Did not test it with a script.
Ubuntu server, Raspberry Pi, PiFace 2, RFXCom, Z-wave Stick, Kaku, Sensor
dressie
- Domoticz version: V2020.2
I went back to stable and it works again! Also Pushbullet didn't work on beta. Something must go wrong. Only on Windows.
jvandenbroek
This would indicate that the server can'tbe verified correctly. Beta contains an extra security check on the called URL.
Do you get a certificate error when opening https://api.pushover.net in Internet Explorer/Edge? If that's the case, something is wrong with the certificate store on your Windows installation.
Edit: Tested it on my Windows 10 installation and got the same problem. Created a pull request to fix this: https://github.com/domoticz/domoticz/pull/1637
Verstuurd vanaf mijn SM-N930F met Tapatalk
dressie
Thanks! Glad I'm not losing my mindjvandenbroek wrote:This would indicate that the server can'tbe verified correctly. Beta contains an extra security check on the called URL.
