Sonoff Switch
corederoma82
Sonoff Switch
Post by corederoma82 »
Hi guys,
I have searched in forum, but I am enough confused.
It's this switch (https://www.itead.cc/smart-home/sonoff-rf.html) able to be used with Domoticz, and it is able for on/off function?
How is the configuratione for Domoticz?
Thanks ;)
Raspberry PI 3, 3x Yeelight bulbs, 1x Yeeligh led strip, 1x Sonoff with ESP826, Controlicz, Kodi
Westcott
Re: Sonoff Switch
Post by Westcott »
Hi Corederoma82,
Yes it can work fully with Domoticz, bidirectional!
I have 2, and there are many others using them.
You first have to upgrade its software, most people use ESPeasy.
corederoma82
Re: Sonoff Switch
Hi, I have configured the switch with Esp, but I have a problem.
I am testing the switch (now it is connected at pc with usb); when I push the switch button, the icon in Domoticz switch on; but if I push again the switch button, the icon don't switch off.
Why?
corederoma82
Re: Sonoff Switch
Oh I have seen the log in domoticz....when I push the button to switch off, log says:
"User: Admin initiated a switch command (23/Scaldabagno/Off)
2017-07-17 21:36:34.660 (Scaldabagno) Light/Switch (Scaldabagno)
2017-07-17 21:36:35.828 User: Admin initiated a switch command (23/Scaldabagno/On)
2017-07-17 21:36:35.828 (Scaldabagno) Light/Switch (Scaldabagno)
corederoma82
Re: Sonoff Switch
I have un update;
if I configure the switch in this way, it seems functioning
But if I select in "Switch Button Type" field the option " Normal switch" I have the problem.....why?
corederoma82
Re: Sonoff Switch
Hi guys,
I have a sonoff switch that I have uodated with EaspEasy firmware.
It seems work because when I push the sonoff button, in software the status became 1 and if I re-push the button the status became 0.
I have problem when I connect the Sonoff Switch at my boiler; the voltage is ok, the Sonoff is on and work but when I press the switch button the led boiler is always swtich off.
