How to restart services with python ?
tontze
Domoticz version: Beta Ch
Post by tontze »
Hi !
I have a conflict problem with my bt beacon and miflora sensor. Whenever i run miflora update, beacon stops responding, so i thought to restart
beacon service in the end of a miflora python script. How is it easiest to do ?
Smartthings
zigbee2mqtt
RFLink 433mhz / Nrf 2.4Ghz
Mi Light
esp8266MiLight Hub
ubee
Domoticz version: 2021.1
Re: How to restart services with python ?
Post by ubee »
I would have started the beacon service as a systemd service. Then it will be automatically restarted by the Linux system if it terminates for some reason. If you do not know how to start a script as a systemd service, you can find an example on github, bengtner/GPIOinput. You write a small service definition file and put in /etc/systemd/system, then use the systemctl command to enable the service.
tontze
Post by tontze »
Beaconing is made by this wiki :
http://www.domoticz.com/wiki/Presence_d ... gy_Beacon)
And is it run from init.d
It runs hci0 port, but if anything else accesses it, it will stop responding, im not sure does it die, or just doesnt respond anymore ..
Im noob on this so .. :)
EDIT: by checking status of a service, i see it is running, but not responding
-T
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
ubee
Post by ubee »
I see, since status reports "running" no system surveillance will solve your problem.
I'm sorry, but I can't help you in this matter.
tontze
Post by tontze »
ubee wrote:I see, since status reports "running" no system surveillance will solve your problem.
Ok, thnx anyways, an attempt was made :D
Does anyone else have ideas ? I simply would like to "sudo /etc/init.d/beqacon restart" service at the end of miflora script. Mi flora is run every 6hours.
I just dont know how to do it with python :/
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
gerardvs
Domoticz version: latest-1
Post by gerardvs »
Something like this?
import os
os.system("sudo /etc/init.d/beqacon restart")
Make sure sudo is not asking for a password.
--Gerard
tontze
Post by tontze »
gerardvs wrote:Something like this?
import os
--Gerard
Thanks, that did it :)
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
Lora46
Post by Lora46 »
Ease from there you'll have the ability to download Fildo the within the Fildo App. The Fildo Apk could be downloaded.
devros
Post by devros »
hello, iv had same problem as you, so i changed script
with this command
os.system("timeout 2 hcitool lescan 5")
miflora works OK in my tests and it works without sudo
#!/usr/bin/python3
import urllib.request
import base64
import time
import os
from miflora.miflora_poller import MiFloraPoller, \
    MI_CONDUCTIVITY, MI_MOISTURE, MI_LIGHT, MI_TEMPERATURE, MI_BATTERY
# Settings for the domoticz server
# Forum see: http://domoticz.com/forum/viewtopic.php?f=56&t=13306&hilit=mi+flora&start=20#p105255
domoticzserver   = "XXXX"
domoticzusername = "XXXX"
domoticzpassword = "XXXX"
# So id devices use: sudo hcitool lescan
base64string = base64.encodestring(('%s:%s' % (domoticzusername, domoticzpassword)).encode()).decode().replace('\n', '')
def domoticzrequest (url):
  request = urllib.request.Request(url)
  request.add_header("Authorization", "Basic %s" % base64string)
  response = urllib.request.urlopen(request)
  return response.read()
def update(address,idx_moist,idx_temp,idx_lux,idx_cond):
    poller = MiFloraPoller(address)
    loop = 0
    try:
        temp = poller.parameter_value("temperature")
    except:
        temp = 201
    while loop < 2 and temp > 200:
        print("Patched: Error reading value retry after 5 seconds...\n")
        time.sleep(5)
        loop += 1
        try:
        except:
            temp = 201
    if temp > 200:
        print("Patched: Error reading value\n")
        return
    global domoticzserver
    print("Mi Flora: " + address)
    print("Firmware: {}".format(poller.firmware_version()))
    print("Name: {}".format(poller.name()))
    print("Temperature: {}°C".format(poller.parameter_value("temperature")))
    print("Moisture: {}%".format(poller.parameter_value(MI_MOISTURE)))
    print("Light: {} lux".format(poller.parameter_value(MI_LIGHT)))
    print("Fertility: {} uS/cm?".format(poller.parameter_value(MI_CONDUCTIVITY)))
    print("Battery: {}%".format(poller.parameter_value(MI_BATTERY)))
    val_bat  = "{}".format(poller.parameter_value(MI_BATTERY))
    # Update temp
    val_temp = "{}".format(poller.parameter_value("temperature"))
    domoticzrequest("http://" + domoticzserver + "/json.htm?type=command&param=udevice&idx=" + idx_temp + "&nvalue=0&svalue=" + val_temp + "&battery=" + val_bat)
    # Update lux
    val_lux = "{}".format(poller.parameter_value(MI_LIGHT))
    domoticzrequest("http://" + domoticzserver + "/json.htm?type=command&param=udevice&idx=" + idx_lux + "&svalue=" + val_lux + "&battery=" + val_bat)
    # Update moisture
    val_moist = "{}".format(poller.parameter_value(MI_MOISTURE))
    domoticzrequest("http://" + domoticzserver + "/json.htm?type=command&param=udevice&idx=" + idx_moist + "&svalue=" + val_moist + "&battery=" + val_bat)
    # Update fertility
    val_cond = "{}".format(poller.parameter_value(MI_CONDUCTIVITY))
    domoticzrequest("http://" + domoticzserver + "/json.htm?type=command&param=udevice&idx=" + idx_cond + "&svalue=" + val_cond + "&battery=" + val_bat)
    time.sleep(1)
# format address, moist (%), temp (°C), lux, fertility
print ("predping")
update("C4:7C:8D:61:B4:DA","142","133","136","143")
