How to restart services with python ?
tontze
- Domoticz version: Beta Ch
Hi !
I have a conflict problem with my bt beacon and miflora sensor. Whenever i run miflora update, beacon stops responding, so i thought to restart
beacon service in the end of a miflora python script. How is it easiest to do ?
Smartthings
zigbee2mqtt
RFLink 433mhz / Nrf 2.4Ghz
Mi Light
esp8266MiLight Hub
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
ubee
- Domoticz version: 2021.1
Re: How to restart services with python ?
I would have started the beacon service as a systemd service. Then it will be automatically restarted by the Linux system if it terminates for some reason. If you do not know how to start a script as a systemd service, you can find an example on github, bengtner/GPIOinput. You write a small service definition file and put in /etc/systemd/system, then use the systemctl command to enable the service.
tontze
Beaconing is made by this wiki :
http://www.domoticz.com/wiki/Presence_d ... gy_Beacon)
And is it run from init.d
It runs hci0 port, but if anything else accesses it, it will stop responding, im not sure does it die, or just doesnt respond anymore ..
Im noob on this so ..
EDIT: by checking status of a service, i see it is running, but not responding
-T
-T
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
ubee
I see, since status reports "running" no system surveillance will solve your problem.
I'm sorry, but I can't help you in this matter.
tontze
Ok, thnx anyways, an attempt was madeubee wrote:I see, since status reports "running" no system surveillance will solve your problem.
Does anyone else have ideas ? I simply would like to "sudo /etc/init.d/beqacon restart" service at the end of miflora script. Mi flora is run every 6hours.
I just dont know how to do it with python :/
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
gerardvs
- Domoticz version: latest-1
Something like this?
Make sure sudo is not asking for a password.
--Gerard
import os
os.system("sudo /etc/init.d/beqacon restart")--Gerard
tontze
Thanks, that did itgerardvs wrote:Something like this?Make sure sudo is not asking for a password.Code: Select all
import os os.system("sudo /etc/init.d/beqacon restart")
--Gerard
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
Ease from there you'll have the ability to download Fildo the within the Fildo App. The Fildo Apk could be downloaded.
hello, iv had same problem as you, so i changed script
with this command
miflora works OK in my tests and it works without sudo
with this command
os.system("timeout 2 hcitool lescan 5")Code: Select all
#!/usr/bin/python3
import urllib.request
import base64
import time
import os
from miflora.miflora_poller import MiFloraPoller, \
MI_CONDUCTIVITY, MI_MOISTURE, MI_LIGHT, MI_TEMPERATURE, MI_BATTERY
# Settings for the domoticz server
# Forum see: http://domoticz.com/forum/viewtopic.php?f=56&t=13306&hilit=mi+flora&start=20#p105255
domoticzserver = "XXXX"
domoticzusername = "XXXX"
domoticzpassword = "XXXX"
# So id devices use: sudo hcitool lescan
base64string = base64.encodestring(('%s:%s' % (domoticzusername, domoticzpassword)).encode()).decode().replace('\n', '')
def domoticzrequest (url):
request = urllib.request.Request(url)
request.add_header("Authorization", "Basic %s" % base64string)
response = urllib.request.urlopen(request)
return response.read()
def update(address,idx_moist,idx_temp,idx_lux,idx_cond):
poller = MiFloraPoller(address)
loop = 0
try:
temp = poller.parameter_value("temperature")
except:
temp = 201
while loop < 2 and temp > 200:
print("Patched: Error reading value retry after 5 seconds...\n")
time.sleep(5)
loop += 1
try:
except:
temp = 201
if temp > 200:
print("Patched: Error reading value\n")
return
global domoticzserver
print("Mi Flora: " + address)
print("Firmware: {}".format(poller.firmware_version()))
print("Name: {}".format(poller.name()))
print("Temperature: {}°C".format(poller.parameter_value("temperature")))
print("Moisture: {}%".format(poller.parameter_value(MI_MOISTURE)))
print("Light: {} lux".format(poller.parameter_value(MI_LIGHT)))
print("Fertility: {} uS/cm?".format(poller.parameter_value(MI_CONDUCTIVITY)))
print("Battery: {}%".format(poller.parameter_value(MI_BATTERY)))
val_bat = "{}".format(poller.parameter_value(MI_BATTERY))
# Update temp
val_temp = "{}".format(poller.parameter_value("temperature"))
domoticzrequest("http://" + domoticzserver + "/json.htm?type=command¶m=udevice&idx=" + idx_temp + "&nvalue=0&svalue=" + val_temp + "&battery=" + val_bat)
# Update lux
val_lux = "{}".format(poller.parameter_value(MI_LIGHT))
domoticzrequest("http://" + domoticzserver + "/json.htm?type=command¶m=udevice&idx=" + idx_lux + "&svalue=" + val_lux + "&battery=" + val_bat)
# Update moisture
val_moist = "{}".format(poller.parameter_value(MI_MOISTURE))
domoticzrequest("http://" + domoticzserver + "/json.htm?type=command¶m=udevice&idx=" + idx_moist + "&svalue=" + val_moist + "&battery=" + val_bat)
# Update fertility
val_cond = "{}".format(poller.parameter_value(MI_CONDUCTIVITY))
domoticzrequest("http://" + domoticzserver + "/json.htm?type=command¶m=udevice&idx=" + idx_cond + "&svalue=" + val_cond + "&battery=" + val_bat)
time.sleep(1)
# format address, moist (%), temp (°C), lux, fertility
print ("predping")
update("C4:7C:8D:61:B4:DA","142","133","136","143")
