Database
Noppie
Database
Post by Noppie »
Due to a re-installation I've added a new sensor (with a new IDX) for my Solar panels. Is it possible to link the old data to the new sensor based on the IDX?
Egregius
Domoticz version: v2024.7
Re: Database
Post by Egregius »
You could update the database directly.
Noppie
Re: Database
Post by Noppie »
Yes I know, but where is the history stored? I queried the database but I can't find the history of my solar panels.......
Egregius
Re: Database
Post by Egregius »
Probably in tables meter and meter_calendar
Noppie
Re: Database
Post by Noppie »
I will give it a try......
Nautilus
Re: Database
Post by Nautilus »
Noppie wrote:Hi,
When you have both new and old in Domoticz open the edit window of the old and select "Replace...", then select the new as the replacement and your old data will be moved to the new sensor.
But yes, you can do the same directly by editing the database, just a lot easier via the UI :)
Noppie
Re: Database
Post by Noppie »
Thanks Nautilus,
unfortunately I deleted the old one so, Replacing isn't an option anymore.....
