Due to a re-installation I've added a new sensor (with a new IDX) for my Solar panels. Is it possible to link the old data to the new sensor based on the IDX?
Database
- Egregius
- Domoticz version: v2024.7
Re: Database
You could update the database directly.
Noppie
Re: Database
Yes I know, but where is the history stored? I queried the database but I can't find the history of my solar panels.......
- Egregius
Re: Database
Probably in tables meter and meter_calendar
Noppie
Re: Database
I will give it a try......
Nautilus
Re: Database
When you have both new and old in Domoticz open the edit window of the old and select "Replace...", then select the new as the replacement and your old data will be moved to the new sensor.Noppie wrote:Hi,
But yes, you can do the same directly by editing the database, just a lot easier via the UI
Noppie
Re: Database
Thanks Nautilus,
unfortunately I deleted the old one so, Replacing isn't an option anymore.....
