I wanna make a virtual device (switch) that changes a device parameter of my fibaro wall plug (the led ring) Is this possible and how?
Thanks in advance!
Did you try searching? There's been some discussion about this before, at least:jaha wrote:Bump, anybody?
Nautilus wrote:Did you try searching? There's been some discussion about this before, at least:jaha wrote:Bump, anybody?
viewtopic.php?f=4&t=15141&p=111305&hili ... ng#p111305
viewtopic.php?t=8605
Hope this helps
Sorry, I don't use it myself so no idea to advance the cause furtherjaha wrote:Nautilus wrote:Did you try searching? There's been some discussion about this before, at least:jaha wrote:Bump, anybody?
Hope this helps
Thank you got it working when I paste the url in the browser byt cant got i working with a switch action or a switch selector by trying to post this: https://127.0.0.1/json.htm?type=command ... lvbg%3D%3D
Should https work with switch actions? I also have excluded the 127.0.0.* from auth.
Yes of course its encryptedNautilus wrote:Sorry, I don't use it myself so no idea to advance the cause furtherjaha wrote:Nautilus wrote:
Hope this helps
Should https work with switch actions? I also have excluded the 127.0.0.* from auth.Is https necessary by the way?
Why do you want to encrypt it when you keep the command in your own network, even on the same machine??jaha wrote:Yes of course its encryptedNautilus wrote:Sorry, I don't use it myself so no idea to advance the cause furtherjaha wrote:
Just like the extra protection if somebody unlikely would hack in to my network. (I'm a network engineer) Tried with the port but doesn't help using default 443 for SSL.RayAmsterdam wrote:Btw, I am missing the port number in your json URL.
