Virtual switch to change device parameter
jaha
Post by jaha »
I wanna make a virtual device (switch) that changes a device parameter of my fibaro wall plug (the led ring) Is this possible and how?
Thanks in advance! :D
jaha
Re: Virtual switch to change device parameter
Post by jaha »
In vera you could send this via lua is there a smilar way in domoticz? luup.variable_set( "urn:micasaverde-com:serviceId:ZWaveDevice1", "VariablesSet", "12,1d,15", 48 )
jaha
Post by jaha »
Bump, anybody? :D
Nautilus
Post by Nautilus »
jaha wrote:Bump, anybody? :D
Did you try searching? There's been some discussion about this before, at least:
viewtopic.php?f=4&t=15141&p=111305&hili ... ng#p111305
viewtopic.php?t=8605
Hope this helps :)
jaha
Post by jaha »
Hope this helps :)
Thank you got it working when I paste the url in the browser byt cant got i working with a switch action or a switch selector by trying to post this: https://127.0.0.1/json.htm?type=command ... lvbg%3D%3D
Should https work with switch actions? I also have excluded the 127.0.0.* from auth.
Nautilus
Post by Nautilus »
Hope this helps :)
Sorry, I don't use it myself so no idea to advance the cause further :) Is https necessary by the way?
jaha
Post by jaha »
Hope this helps :)
Yes of course its encrypted :)
RayAmsterdam
Re: RE: Re: Virtual switch to change device parameter
Post by RayAmsterdam »
Why do you want to encrypt it when you keep the command in your own network, even on the same machine??
RayAmsterdam
Btw, I am missing the port number in your json URL.
jaha
Post by jaha »
RayAmsterdam wrote:Btw, I am missing the port number in your json URL.
Just like the extra protection if somebody unlikely would hack in to my network. (I'm a network engineer) Tried with the port but doesn't help using default 443 for SSL.
