Everything else can be set via domoticz but i would like to turn off leds.
Nothing happens when i do so, and led stays enable mode.
Aeotec ZW100 MultiSensor 6 Led DISABLE problem
- Domoticz version: Stable
Re: Aeotec ZW100 MultiSensor 6 Led DISABLE problem
What is the software version of your multi sensor?
You can find this in the ozw control panel.
Greetz YcKe
Greetz YcKe
Is this correct?
Protocol Version: 4.05
Application Version: 1.07
I bought 4pcs of these about two weeks ago, all seems to be same.
Yes this is correct.
Your application version is 1.07. Disabling the led is only supported since 1.08.
You can updated the firmware for your modules if you like, but read the warnings for this firmware version first. It could possibly drain your batteries in some cases.
Have a look at: https://aeotec.freshdesk.com/support/so ... 1-02-2016-
Greetz YcKe
Greetz YcKe
Thanks! That explains it
I just got everything working, so leds shine for now...
I dont want mess my adresses doing a firmware updates.
If i exclude/include these, i get four "empty" adresses in my system. I want these id´s to be in perfect specific order.
Is it possible to edit z-stick afterwards to be like now?
011 (0x0b)
012 (0x0c)
013 (0x0d)
014 (0x0e)
Btw, i have all these powered via usb.
011 (0x0b)
012 (0x0c)
013 (0x0d)
014 (0x0e)
Hallo
Is there a problem when the devices not are in a specific numerical order, some addresses (NodeId) are empty? Or is it more a point of order?
If I reckon correctly, you can perform a firmware update without losing the current device id's. (If you are using the same controller to update the firmware...)
In the end it won't break anything. You only have to update some device name in case you will need to include/exclude your device.
I would suggest you try it with one of your devices and proceed according.
Keep us posted how it went!
Greetz YcKe
Greetz YcKe
@AimoPaukku : I find it a little odd when you say "everything else can be set via domoticz". Could you please confirm if you have successfully managed to change all of the values? Thanks.
For example,
+ index 41, cannot be changed to say for example 10, or 5. That is because the size has changed from "2" to "3" in v1.07.
+ Wake-up Interval: cannot be changed from 3600 to anything else.
I have attached the latest zw100.xml file from OZW. Kindly let me know if you are using a different config file. Many thanks.
For example,
