Aeotec ZW100 MultiSensor 6 Led DISABLE problem
AimoPaukku
Domoticz version: Stable
Post by AimoPaukku »
Everything else can be set via domoticz but i would like to turn off leds.
Nothing happens when i do so, and led stays enable mode.
YcKe
Re: Aeotec ZW100 MultiSensor 6 Led DISABLE problem
Post by YcKe »
What is the software version of your multi sensor?
You can find this in the ozw control panel.
Greetz YcKe
AimoPaukku
Is this correct?
Protocol Version: 4.05
Application Version: 1.07
I bought 4pcs of these about two weeks ago, all seems to be same.
YcKe
Post by YcKe »
Yes this is correct.
Your application version is 1.07. Disabling the led is only supported since 1.08.
You can updated the firmware for your modules if you like, but read the warnings for this firmware version first. It could possibly drain your batteries in some cases.
Have a look at: https://aeotec.freshdesk.com/support/so ... 1-02-2016-
Greetz YcKe
AimoPaukku
Thanks! That explains it
I just got everything working, so leds shine for now...
I dont want mess my adresses doing a firmware updates.
If i exclude/include these, i get four "empty" adresses in my system. I want these id´s to be in perfect specific order.
Is it possible to edit z-stick afterwards to be like now?
011 (0x0b)
012 (0x0c)
013 (0x0d)
014 (0x0e)
Btw, i have all these powered via usb.
andersbz
Post by andersbz »
Hallo
Is there a problem when the devices not are in a specific numerical order, some addresses (NodeId) are empty? Or is it more a point of order?
YcKe
Post by YcKe »
If I reckon correctly, you can perform a firmware update without losing the current device id's. (If you are using the same controller to update the firmware...)
In the end it won't break anything. You only have to update some device name in case you will need to include/exclude your device.
I would suggest you try it with one of your devices and proceed according.
Keep us posted how it went!
Greetz YcKe
kman
Post by kman »
@AimoPaukku : I find it a little odd when you say "everything else can be set via domoticz". Could you please confirm if you have successfully managed to change all of the values? Thanks.
For example,
+ index 41, cannot be changed to say for example 10, or 5. That is because the size has changed from "2" to "3" in v1.07.
+ Wake-up Interval: cannot be changed from 3600 to anything else.
I have attached the latest zw100.xml file from OZW. Kindly let me know if you are using a different config file.
zw100.xml
Aeotec ZW12
(11.71 KiB) Downloaded 114 times
Many thanks.
Users browsing this forum: madpatrick and 1 guest
