I gess my question is a very easy and noobie question, but i can't figure it out even after 4 weeks of trying.
I have Danfoss Z-Wave Radiator Thermostaat Living Connect Z and i would like to have to temperature automatically set low after 11 o'clock. At this moment i have the script you can see in the screenshot. Unfortunately it does not do the trick.
Again it is probably very easy to fix, but i just can not find my fault.
Lowering the temp with danfoss radiator
modular
- Capture.PNG (9.68 KiB) Viewed 1907 times
Skippiemanz
- Domoticz version: 4.10233
Re: Lowering the temp with danfoss radiator
Why not use the build in timer in the thermostat setpoint device? Would be way easier!
modular
Hi thx for your reply. Not sure what you mean? I do not think it has that option as far as i know of. This is the type i got
Skippiemanz
It's the timer button.
In here you can set the value and time etc.
modular
Aaaah i totaly over lookt that option. Thank you so much! Gess we all have to start somewhere ☺
modular
It works thank you! i knew it had to be something simple
Skippiemanz
You're welcome! There is so much to Learn
