Lowering the temp with danfoss radiator
modular
Post by modular »
I gess my question is a very easy and noobie question, but i can't figure it out even after 4 weeks of trying.
I have Danfoss Z-Wave Radiator Thermostaat Living Connect Z and i would like to have to temperature automatically set low after 11 o'clock. At this moment i have the script you can see in the screenshot. Unfortunately it does not do the trick.
Again it is probably very easy to fix, but i just can not find my fault.
Skippiemanz
Domoticz version: 4.10233
Re: Lowering the temp with danfoss radiator
Post by Skippiemanz »
Why not use the build in timer in the thermostat setpoint device? Would be way easier!
modular
Post by modular »
Hi thx for your reply. Not sure what you mean? I do not think it has that option as far as i know of. This is the type i got
Skippiemanz
It's the timer button.
In here you can set the value and time etc.
modular
Post by modular »
Aaaah i totaly over lookt that option. Thank you so much! Gess we all have to start somewhere ☺
modular
Post by modular »
It works thank you! i knew it had to be something simple
Skippiemanz
You're welcome! There is so much to Learn
