Kitty Litter Tracking Sensor
ben53252642
Post by ben53252642 »
I bought the ScoopFree Ultra kitty litter and added a Z-Wave magnetic door sensor at the end part to sense when the "storage section" opens and closes.
Each time the cat uses the kitty litter it updates a counter in Domoticz so I can tell when the kitty litter needs changing (after x cycles):
The device name for the magnetic door sensor is: Kitty Litter
The device name for the counter sensor is: Kitty Litter Cycles
You may need to change the "Closed" to "Open" depending on your setup, it's a pretty simple script.
time = os.date("*t")
counter = otherdevices_svalues['Kitty Litter Cycles']
counter = tonumber(counter)
t1 = os.time()
s1 = otherdevices_lastupdate['Kitty Litter Cycles']
year1 = string.sub(s1, 1, 4)
month1 = string.sub(s1, 6, 7)
day1 = string.sub(s1, 9, 10)
hour1 = string.sub(s1, 12, 13)
minutes1 = string.sub(s1, 15, 16)
seconds1 = string.sub(s1, 18, 19)
t2 = os.time{year=year1, month=month1, day=day1, hour=hour1, min=minutes1, sec=seconds1}
cycletime = (os.difftime (t1, t2))
if (devicechanged["Kitty Litter"] == 'Closed' and cycletime > 240) then
counter = counter + 1
commandArray['UpdateDevice'] = otherdevices_idx['Kitty Litter Cycles'] .. '|0|' .. tonumber(counter)
Screen Shot 2017-01-22 at 11.11.58 pm.png (64.86 KiB) Viewed 3555 times
Screen Shot 2017-01-22 at 11.12.09 pm.png (238.17 KiB) Viewed 3555 times
Last edited by ben53252642 on Sunday 22 January 2017 17:08, edited 1 time in total.
Calzor Suzay
Domoticz version: 4.9700
Re: Kitty Litter Tracking Sensor
Post by Calzor Suzay »
Poop tracker, I love it :lol:
jjnj
Post by jjnj »
Ha great, i was looking for this. What type of sensir did you create for the cycles?
Sent from my LG-F800L using Tapatalk
ben53252642
jjnj wrote:Ha great, i was looking for this. What type of sensir did you create for the cycles?
It's just a counter, also fyi they sell re-usable trays for the ScoopFree on Amazon.
randriese
Post by randriese »
this is pure brilliance!
Bernoo
Post by Bernoo »
Hello Ben,
i use your simple script, with a virtual switch (to try) and change the names from the sensor and counter in the Script (not more).
But it doesn't work.
In the Stratus Protocoll is this error:
Error: EventSystem: in brennerstarts: [string "commandArray = {}..."]:17: attempt to index global 'devicechanged' (a nil value)
What is wrong?
Thx Bernoo
(Domoticz V3.88.41)
don't drink whisky without water and don't drink water without whisky...
ben53252642
You probably have the Lua script set to type "ALL" instead of "Device". Look on the events page.
Bernoo
Post by Bernoo »
Hello Ben,
yes, that was wrong, and the error message is gone. But he still does not count. There must be another mistake.
I do not understand that.
Thx for your fast help.
Grettings
Bernoo
ben53252642
Bernoo wrote: Sunday 18 February 2018 20:11 Hello Ben,
Grettings
Bernoo
If your using a virtual switch for testing, that would only have "On / Off" states.
This line needs to be changed:
To:
if (devicechanged["Kitty Litter"] == 'Off') then
I removed the cycle time, basically each time you turn off the test switch it should now + the counter. This is only so you can see it working with the test script, the original script above should work fine with an actual door / contact sensor.
Bernoo
Post by Bernoo »
Ben,
that was it, it works!!! Thank you,
thank you for your help.
I change it after install the Hardware Switch next Week
Grettings
Bernoo
askmurphy
Post by askmurphy »
Nice !
Would be nice if there was a reset-button (virtual on the screen) which could be pressed after cleaning the cat-litter.
How can we do that ?
I have made some hardware for the Cat Robot Litter, will post that as soon it's ready (now in prototype fase, works nice already).
;-) Arthur
askmurphy
Post by askmurphy »
I am trying to make a reset button and a counter.
What I want to do is this:
1) a counter which counts every cat litter cycle, that works now.
2) a total counter which counts the total cycles
3) a reset button which reset the counter (1) to 0.
I have made a uservariable:
'KattenbakCyclusTeller Integer'
And I use the script below.
If I add the line 'uservariables['Kattenbakcyclusteller'] = otherdevices_idx['Kattenbakcycles'] ' the script doesn't work anymore.
I hope somebody can help a little ?
Regards,
;-) Arthur
counter = otherdevices_svalues['Kattenbakcycles']
t1 = os.time()
s1 = otherdevices_lastupdate['Kattenbakcycles']
if (devicechanged["Kattenbaksensor"] == 'On' and cycletime > 240) then
-- value=0
value = counter
commandArray['UpdateDevice'] = otherdevices_idx['Kattenbakcycles'] .. '|0|' .. tonumber(value)
-- uservariables['Kattenbakcyclusteller'] = otherdevices_idx['Kattenbakcycles']
jjnj
Post by jjnj »
askmurphy wrote: Monday 26 March 2018 22:03 I am trying to make a reset button and a counter.
Regards,
;-) Arthur
t1 = os.time()
-- value=0
value = counter
Did you manage to get this working?
askmurphy
Post by askmurphy »
It works !
Look at this:
Kattenbak-code:
-- You probably have the Lua script set to type "ALL" instead of "Device". Look on the events page.
totalcounter = otherdevices_svalues['Kattenbakcycle-totaalteller']
totalcounter = tonumber(totalcounter)
t1 = os.time()
if (devicechanged["Kattenbaksensor"] == 'On' and cycletime > 60) then
totalvalue = totalcounter + 1
    table.insert (commandArray, { ['UpdateDevice'] = otherdevices_idx['Kattenbakcycles'] .. '|0|' .. tonumber(counter) } )
    table.insert (commandArray, { ['UpdateDevice'] = otherdevices_idx['Kattenbakcycle-totaalteller'] .. '|0|' .. tonumber(totalvalue) } )
Kattenbak-reset code:
if (devicechanged["Reset kattenbak teller"] == 'Group On') then
       table.insert (commandArray, { ['UpdateDevice'] = otherdevices_idx['Kattenbakcycles'] .. '|0|' .. tonumber(0) } )
      --  table.insert (commandArray, { ['UpdateDevice'] = otherdevices_idx['Kattenbakcycle-totaalteller'] .. '|0|' .. tonumber(0) } )
--   commandArray['UpdateDevice'] = otherdevices_idx['Kattenbakcycles'] .. '|0|' .. tonumber(9)
  -- commandArray['UpdateDevice'] = otherdevices_idx['Kattenbakcycle-totaalteller'] .. '|0|' .. tonumber(9)
Hardware:
234 Kattenbakcycle-totaalteller 00082234 1 Kattenbakcycle-totaalteller General Custom Sensor
231 Reset kattenbak teller 00014137 1 Reset kattenbak teller Light/Switch
230 My Sensors 00000001 0 Kattenbaksensor Light/Switch AC
224 Kattenbakcycles 00082224 1 Kattenbakcycles General Custom Sensor
I will post all details on thingiverse next week, I will let you know that here.
