Check last seen?
Posted: Saturday 21 January 2017 15:44
by Calzor Suzay
Does anyone have a script written that would check a list of given devices for their 'Last seen' status of say more than 5 days then report it somehow?
I'm trying to capture devices such as PIR, door sensors etc. where potentially the battery has died
Re: Check last seen?
Posted: Saturday 21 January 2017 16:30
by Siewert308SW
Calzor Suzay wrote:Does anyone have a script written that would check a list of given devices for their 'Last seen' status of say more than 5 days then report it somehow?
Wiki has a few
Posted: Saturday 21 January 2017 19:27
by Calzor Suzay
I couldn't find a Wiki for dzVents only the Github and the examples there seem to be about 'pinging' devices to see if they are alive.
Unless I missed something?
Posted: Sunday 22 January 2017 1:12
by Siewert308SW
Calzor Suzay wrote:I couldn't find a Wiki for dzVents only the Github and the examples there seem to be about 'pinging' devices to see if they are alive.
You didn't mention you want info for Dz, then ask there.
As for Lua, you could amend this one:
https://www.domoticz.com/wiki/Get_Sensors_Status
Posted: Sunday 22 January 2017 3:29
by elmortero
I think what are looking for is in the dzvents examples.
https://github.com/dannybloe/dzVents/tr ... s/examples
Look for check dead devices.lua
That script checks for device that have not been updated for x minutes
Posted: Sunday 22 January 2017 13:19
by Calzor Suzay
Siewert308SW wrote:You didn't mention you want info for Dz, then ask there.
This post is in the specific dzVents Lua Framework sub forum so one could assume I'm asking about that
Posted: Sunday 22 January 2017 13:27
by Siewert308SW
Calzor Suzay wrote:Siewert308SW wrote:You didn't mention you want info for Dz, then ask there.
My mistake, didn't notice that.
But nevermind hope someone with dzvent knowledge can help.
Posted: Sunday 29 January 2017 21:48
by Calzor Suzay
Think I got this working by taking the sample and swopping my devices and timing etc.
Posted: Friday 20 March 2020 9:46
by MikeF
This is exactly what I am looking for, as I have a couple of devices which stop sending from time to time - except that, as it stands, this script will keep sending every 5 minutes. Is there a way of changing this, so that it only sends once?
Posted: Friday 20 March 2020 18:35
by waaren
MikeF wrote: Friday 20 March 2020 9:46
This should send the notification once every 12 hours (adjustable)
Check dead device using their description
local repeatNotificationHours = 12
return
on =
timer =
'every 5 minutes during daytime',
data =
notifications =
initial = {},
execute = function(dz, item)
local function notify(device)
local message = 'Device ' .. device.name .. ' seems to be dead. No update for ' .. device.lastUpdate.minutesAgo .. ' minutes'
dz.log(message)
if dz.data.notifications[device.name] and dz.data.notifications[device.name] > dz.time.dDate then
dz.log('No notification needed now')
dz.notify('Dead devices', message, dz.PRIORITY_HIGH)
dz.data.notifications[device.name] = dz.time.dDate + repeatNotificationHours * 3600
local maxIdleTime
dz.devices().forEach(function(device)
if (device.description or ''):match('CDA:%s*%d+') then
maxIdleTime = (device.description):gsub('CDA:',''):gsub(' ','')
maxIdleTime = tonumber(maxIdleTime)
if device.lastUpdate.minutesAgo > maxIdleTime then
notify(device)
end)
Re: Check last seen? [Solved]
Posted: Friday 20 March 2020 23:43
by MikeF
Many thanks, @waaren - this is a very neat solution, and works nicely!
I had tried extending the check dead devices.lua script to update an alert sensor but only trigger an email if this had been set to red in less than 24 hours. However, this is much neater, as I don't need to edit the script to insert the names of the devices I want to check - instead, I can use the device description in the Domoticz GUI for the devices I want to monitor.
