Check last seen?  [Solved]
Calzor Suzay
Domoticz version: 4.9700
Check last seen?
Post by Calzor Suzay »
Does anyone have a script written that would check a list of given devices for their 'Last seen' status of say more than 5 days then report it somehow?
I'm trying to capture devices such as PIR, door sensors etc. where potentially the battery has died :o
Siewert308SW
Domoticz version: Stable
Re: Check last seen?
Post by Siewert308SW »
Calzor Suzay wrote:Does anyone have a script written that would check a list of given devices for their 'Last seen' status of say more than 5 days then report it somehow?
Wiki has a few ;-)
Setup:
- DS923+ Docker
Domoticz Latest Stable
Mosquitto / ZwaveJSUI @ Aeotec Z-Stick Gen5+ / PiHole Unbound
P1 USB Gas/Power, HW watermeter
- A lot of Zwave switches, contacts, plugs, smoke/Co2 ect
- DiY 7.5kWh Solar Storage @ GitHuB
Calzor Suzay
I couldn't find a Wiki for dzVents only the Github and the examples there seem to be about 'pinging' devices to see if they are alive.
Unless I missed something?
Siewert308SW
Calzor Suzay wrote:I couldn't find a Wiki for dzVents only the Github and the examples there seem to be about 'pinging' devices to see if they are alive.
You didn't mention you want info for Dz, then ask there.
As for Lua, you could amend this one:
https://www.domoticz.com/wiki/Get_Sensors_Status
Setup:
- DS923+ Docker
elmortero
Domoticz version: 3.9639
Post by elmortero »
I think what are looking for is in the dzvents examples.
https://github.com/dannybloe/dzVents/tr ... s/examples
Look for check dead devices.lua
That script checks for device that have not been updated for x minutes
Calzor Suzay
Siewert308SW wrote:You didn't mention you want info for Dz, then ask there.
This post is in the specific dzVents Lua Framework sub forum so one could assume I'm asking about that :roll:
Siewert308SW
My mistake, didn't notice that.
But nevermind hope someone with dzvent knowledge can help.
Setup:
- DS923+ Docker
Calzor Suzay
Think I got this working by taking the sample and swopping my devices and timing etc. :)
MikeF
Domoticz version: V2022.2
Post by MikeF »
elmortero wrote: Sunday 22 January 2017 3:29 I think what are looking for is in the dzvents examples.
This is exactly what I am looking for, as I have a couple of devices which stop sending from time to time - except that, as it stands, this script will keep sending every 5 minutes. Is there a way of changing this, so that it only sends once?
MikeF wrote: Friday 20 March 2020 9:46 This is exactly what I am looking for, as I have a couple of devices which stop sending from time to time - except that, as it stands, this script will keep sending every 5 minutes. Is there a way of changing this, so that it only sends once?
This should send the notification once every 12 hours (adjustable)
        Check dead device using their description
local repeatNotificationHours = 12
return
    on =
        timer =
            'every 5 minutes during daytime',
    data =
        notifications =
            initial = {},
    execute = function(dz, item)
        local function notify(device)
            local message = 'Device ' .. device.name .. ' seems to be dead. No update for ' .. device.lastUpdate.minutesAgo .. ' minutes'
            dz.log(message)
            if dz.data.notifications[device.name] and dz.data.notifications[device.name] > dz.time.dDate then
                dz.log('No notification needed now')
                dz.notify('Dead devices', message, dz.PRIORITY_HIGH)
                dz.data.notifications[device.name] = dz.time.dDate + repeatNotificationHours * 3600
        local maxIdleTime
        dz.devices().forEach(function(device)
            if (device.description or ''):match('CDA:%s*%d+') then
                maxIdleTime =  (device.description):gsub('CDA:',''):gsub(' ','')
                maxIdleTime = tonumber(maxIdleTime)
                if device.lastUpdate.minutesAgo > maxIdleTime then
                    notify(device)
        end)
MikeF
Re: Check last seen?  [Solved]
Post by MikeF »
Many thanks, @waaren - this is a very neat solution, and works nicely! :D
I had tried extending the check dead devices.lua script to update an alert sensor but only trigger an email if this had been set to red in less than 24 hours. However, this is much neater, as I don't need to edit the script to insert the names of the devices I want to check - instead, I can use the device description in the Domoticz GUI for the devices I want to monitor.
