I'm trying to capture devices such as PIR, door sensors etc. where potentially the battery has died
Check last seen? [Solved]
Calzor Suzay
- Target OS: -
- Domoticz version: 4.9700
Check last seen?
Does anyone have a script written that would check a list of given devices for their 'Last seen' status of say more than 5 days then report it somehow?
- Siewert308SW
- Domoticz version: Stable
Re: Check last seen?
Wiki has a fewCalzor Suzay wrote:Does anyone have a script written that would check a list of given devices for their 'Last seen' status of say more than 5 days then report it somehow?
Setup:
- DS923+ Docker
Domoticz Latest Stable
Mosquitto / ZwaveJSUI @ Aeotec Z-Stick Gen5+ / PiHole Unbound
P1 USB Gas/Power, HW watermeter
- A lot of Zwave switches, contacts, plugs, smoke/Co2 ect
- DiY 7.5kWh Solar Storage @ GitHuB
- DS923+ Docker
Calzor Suzay
- Target OS: -
I couldn't find a Wiki for dzVents only the Github and the examples there seem to be about 'pinging' devices to see if they are alive.
Unless I missed something?
- Siewert308SW
You didn't mention you want info for Dz, then ask there.Calzor Suzay wrote:I couldn't find a Wiki for dzVents only the Github and the examples there seem to be about 'pinging' devices to see if they are alive.
As for Lua, you could amend this one:
https://www.domoticz.com/wiki/Get_Sensors_Status
Setup:
- DS923+ Docker
- DS923+ Docker
elmortero
- Domoticz version: 3.9639
I think what are looking for is in the dzvents examples.
https://github.com/dannybloe/dzVents/tr ... s/examples
Look for check dead devices.lua
That script checks for device that have not been updated for x minutes
Calzor Suzay
- Target OS: -
This post is in the specific dzVents Lua Framework sub forum so one could assume I'm asking about thatSiewert308SW wrote:You didn't mention you want info for Dz, then ask there.
- Siewert308SW
My mistake, didn't notice that.Calzor Suzay wrote:This post is in the specific dzVents Lua Framework sub forum so one could assume I'm asking about thatSiewert308SW wrote:You didn't mention you want info for Dz, then ask there.
But nevermind hope someone with dzvent knowledge can help.
Setup:
- DS923+ Docker
- DS923+ Docker
Calzor Suzay
- Target OS: -
Think I got this working by taking the sample and swopping my devices and timing etc.
MikeF
- Domoticz version: V2022.2
This is exactly what I am looking for, as I have a couple of devices which stop sending from time to time - except that, as it stands, this script will keep sending every 5 minutes. Is there a way of changing this, so that it only sends once?elmortero wrote: Sunday 22 January 2017 3:29 I think what are looking for is in the dzvents examples.
- waaren
This should send the notification once every 12 hours (adjustable)MikeF wrote: Friday 20 March 2020 9:46 This is exactly what I am looking for, as I have a couple of devices which stop sending from time to time - except that, as it stands, this script will keep sending every 5 minutes. Is there a way of changing this, so that it only sends once?
Check dead device using their description
local repeatNotificationHours = 12
return
on =
timer =
'every 5 minutes during daytime',
data =
notifications =
initial = {},
execute = function(dz, item)
local function notify(device)
local message = 'Device ' .. device.name .. ' seems to be dead. No update for ' .. device.lastUpdate.minutesAgo .. ' minutes'
dz.log(message)
if dz.data.notifications[device.name] and dz.data.notifications[device.name] > dz.time.dDate then
dz.log('No notification needed now')
dz.notify('Dead devices', message, dz.PRIORITY_HIGH)
dz.data.notifications[device.name] = dz.time.dDate + repeatNotificationHours * 3600
local maxIdleTime
dz.devices().forEach(function(device)
if (device.description or ''):match('CDA:%s*%d+') then
maxIdleTime = (device.description):gsub('CDA:',''):gsub(' ','')
maxIdleTime = tonumber(maxIdleTime)
if device.lastUpdate.minutesAgo > maxIdleTime then
notify(device)
end)
}Debian buster, bullseye on RPI-4, Intel NUC.
MikeF
Re: Check last seen? [Solved]
Many thanks, @waaren - this is a very neat solution, and works nicely!
I had tried extending the check dead devices.lua script to update an alert sensor but only trigger an email if this had been set to red in less than 24 hours. However, this is much neater, as I don't need to edit the script to insert the names of the devices I want to check - instead, I can use the device description in the Domoticz GUI for the devices I want to monitor.
