Hi.
I have a little problem witch sctipts located in lua_parses directory: I have no access to global tables like otherdevices, otherdevices_lastupdate and otherdevices_svalues. When i try do check some values in this tables, i have an error in log: (...) variable is nil.
I use this script to update values. My hardware call the spcial URL JSON.
Can you help me ?
global variables like otherdevices, otherdevices_lastupdate and otherdevices_svalues
Nautilus
Re: global variables like otherdevices, otherdevices_lastupdate and otherdevices_svalues
The latest beta has these added, they are not on the stable I'm afraid...
boe666
ok, so it's a normal situation in newest stable version or not ? In the new version (unstable for now) it's working ?
Nautilus
Yes, more info e.g. here: viewtopic.php?p=115099
It's true that in some betas there might be issues, therefore I do not usually update immediately. But I've noticed there has been issues in the stable ones as well - at the time of release at least (fixed very soon of course). So, for the 2½ years I've been using Domoticz I cannot remember any specific issues arising from the fact that I've been on beta and not on stable. But yes, there's of course the risk (therefore daily full backups)...
bellison
i can't tell why it is not working for you, it does for me.
test if this is a solution for you.
sorry i misunderstood you did miss the lua_parses directory reference. but the solution might still be usable
tAllDevicesById = {}
tAllDevicesByName = {}
function getMoreDeviceInformation()
-- by calling this function you can get much more information about a device, eg the number of dim levels
Attributes available:
AddjMulti; AddjMulti2; AddjValue; AddjValue2; BatteryLevel; CustomImage; Data; Description; Favorite;
HardwareID; HardwareName; HardwareType; HardwareTypeVal; HaveDimmer; HaveGroupCmd; HaveTimeout; ID;
Image; IsSubDevice; LastUpdate; Level; LevelInt; MaxDimLevel; Name; Notifications; PlanID; PlanIDs;
Protected; ShowNotifications; SignalLevel; Status; StrParam1; StrParam2; SubType; SwitchType;
SwitchTypeVal; Timers; Type; TypeImg; Unit; Used; UsedByCamera; XOffset; YOffset; idx
local sUrl = 'localhost'
local sPort = '8082'
local json = (loadfile "/home/pi/domoticz/scripts/lua/JSON.lua")() -- For Linux
-- get all the device info needed, since it is not available in lua
local config=assert(io.popen('curl http://'..sUrl..':'..sPort..'/json.htm?type=devices'))
local jsonDevice = config:read('*all')
config:close()
local tDevices = json:decode(jsonDevice)
-- put it in tables for easy access
for k,v in pairs(tDevice['result']) do
--print( "index : " .. k .. " = " .. v['idx'])
tAllDevicesById[v['idx']] = v
tAllDevicesByName[v['Name']] = v
end-
boe666
I tried... result: 2017-01-24 14:15:05.479 Error: CLuaHandler: /home/pi/domoticz/scripts/lua_parsers/d10.lua:27: attempt to index global 'tDevice' (a nil value).
I upgrade domoticz to latest version (unstable) and now it's ok. Example like this:
"function LogVariables(x,depth,name)
for k,v in pairs(x) do
if (depth>0) or ((string.find(k,'device')~=nil) or (string.find(k,'variable')~=nil) or.
(string.sub(k,1,4)=='time') or (string.sub(k,1,8)=='security')) then
if type(v)=="string" then print(name.."['"..k.."'] = '"..v.."'") end
if type(v)=="number" then print(name.."['"..k.."'] = "..v) end
if type(v)=="boolean" then print(name.."['"..k.."'] = "..tostring(v)) end
if type(v)=="table" then LogVariables(v,depth+1,k); end
-- call with this command
LogVariables(_G,0,'');
working very well.
working very well.
boe666
I have another problem.
My some harware send variables to domoticz by special URL with parameters - every 2 second.
So, when i want to monitoring movement detector i have on every 2 sec the same status.
First of all I want to check actual status before i write new status. I can do this now - i can read otherdevices_svalue and can make a decision to use domoticz_updateDevice procedure.
But domoticz after some time show me a red alert - no read on my movement detector.
How can I change a date in otherdevices_lastupdate ?
I tried:
but it's not working.
tem = tonumber(alarm_ruch)
if (tem == 0 and otherdevices_svalues['Naruszenie strefy'] ~= 'Brak ruchu') then domoticz_updateDevice(9,1,'Brak ruchu') else end
if (tem == 1 and otherdevices_svalues['Naruszenie strefy'] ~= 'Wykryto Ruch!') then domoticz_updateDevice(9,4,'Wykryto Ruch!') else end
I tried:
local now_time = os.date("%Y-%m-%d %H:%M:%S");
otherdevices_lastupdate['Naruszenie strefy'] = now_time;
@Bellison
I saw this LUA script with Json commands.
But how do I get a value (OFFSET) which I entered at a device (ADJUST/AANPASSEN and OFFSET)?
for example I entered an offset at device Watermeter (idx 403), offset is 1184308
How can I read out this value and put it in a value like 'watermeteroffset'? So I can use this value with: otherdevices/svalues['Watermeter'] to get the total amount.
Hope you understand my problem
best regards,
Hein
best regards,
Hein
RFXcom433e ver1009,Raspberry Pi,Domoticz v3.5877
KaKu:16c remote,dimmer,wall-sockets,sunscreenswitch
Promax:wall sockets Elro:wall sockets Somfy:RFY screens
TFA:weather station Chinese temperature sensors, smoke detectors, power switches
