global variables like otherdevices, otherdevices_lastupdate and otherdevices_svalues
boe666
Post by boe666 »
Hi.
I have a little problem witch sctipts located in lua_parses directory: I have no access to global tables like otherdevices, otherdevices_lastupdate and otherdevices_svalues. When i try do check some values in this tables, i have an error in log: (...) variable is nil.
I use this script to update values. My hardware call the spcial URL JSON.
Can you help me ?
Nautilus
Re: global variables like otherdevices, otherdevices_lastupdate and otherdevices_svalues
Post by Nautilus »
The latest beta has these added, they are not on the stable I'm afraid...
boe666
Post by boe666 »
ok, so it's a normal situation in newest stable version or not ? In the new version (unstable for now) it's working ?
Nautilus
Post by Nautilus »
Yes, more info e.g. here: viewtopic.php?p=115099
It's true that in some betas there might be issues, therefore I do not usually update immediately. But I've noticed there has been issues in the stable ones as well - at the time of release at least (fixed very soon of course). So, for the 2½ years I've been using Domoticz I cannot remember any specific issues arising from the fact that I've been on beta and not on stable. But yes, there's of course the risk (therefore daily full backups)...
bellison
Post by bellison »
i can't tell why it is not working for you, it does for me.
test if this is a solution for you.
 tAllDevicesById = {}
 tAllDevicesByName = {}
 function getMoreDeviceInformation()
    -- by calling this function you can get much more information about a device, eg the number of dim levels
    Attributes available:
    AddjMulti; AddjMulti2; AddjValue; AddjValue2; BatteryLevel; CustomImage; Data; Description; Favorite;
    HardwareID; HardwareName; HardwareType; HardwareTypeVal; HaveDimmer; HaveGroupCmd; HaveTimeout; ID;
    Image; IsSubDevice; LastUpdate; Level; LevelInt; MaxDimLevel; Name; Notifications; PlanID; PlanIDs;
    Protected; ShowNotifications; SignalLevel; Status; StrParam1; StrParam2; SubType; SwitchType;
    SwitchTypeVal; Timers; Type; TypeImg; Unit; Used; UsedByCamera; XOffset; YOffset; idx
    local sUrl = 'localhost'
    local sPort = '8082'
    local json = (loadfile "/home/pi/domoticz/scripts/lua/JSON.lua")()  -- For Linux
    -- get all the device info needed, since it is not available in lua
    local config=assert(io.popen('curl http://'..sUrl..':'..sPort..'/json.htm?type=devices'))
    local jsonDevice = config:read('*all')
    config:close()
    local tDevices = json:decode(jsonDevice)
    -- put it in tables for easy access
    for k,v in pairs(tDevice['result']) do
        --print( "index : " .. k .. " = " .. v['idx'])
        tAllDevicesById[v['idx']] = v
        tAllDevicesByName[v['Name']] = v
sorry i misunderstood you did miss the lua_parses directory reference. but the solution might still be usable
boe666
Post by boe666 »
I tried... result: 2017-01-24 14:15:05.479 Error: CLuaHandler: /home/pi/domoticz/scripts/lua_parsers/d10.lua:27: attempt to index global 'tDevice' (a nil value).
I upgrade domoticz to latest version (unstable) and now it's ok. Example like this:
"function LogVariables(x,depth,name)
for k,v in pairs(x) do
if (depth>0) or ((string.find(k,'device')~=nil) or (string.find(k,'variable')~=nil) or.
(string.sub(k,1,4)=='time') or (string.sub(k,1,8)=='security')) then
if type(v)=="string" then print(name.."['"..k.."'] = '"..v.."'") end
if type(v)=="number" then print(name.."['"..k.."'] = "..v) end
if type(v)=="boolean" then print(name.."['"..k.."'] = "..tostring(v)) end
if type(v)=="table" then LogVariables(v,depth+1,k); end
-- call with this command
LogVariables(_G,0,'');
working very well.:)
boe666
Post by boe666 »
I have another problem.
My some harware send variables to domoticz by special URL with parameters - every 2 second.
So, when i want to monitoring movement detector i have on every 2 sec the same status.
First of all I want to check actual status before i write new status. I can do this now - i can read otherdevices_svalue and can make a decision to use domoticz_updateDevice procedure.
tem = tonumber(alarm_ruch)
if (tem == 0 and otherdevices_svalues['Naruszenie strefy'] ~= 'Brak ruchu') then domoticz_updateDevice(9,1,'Brak ruchu') else end
if (tem == 1 and otherdevices_svalues['Naruszenie strefy'] ~= 'Wykryto Ruch!') then domoticz_updateDevice(9,4,'Wykryto Ruch!') else end
But domoticz after some time show me a red alert - no read on my movement detector.
How can I change a date in otherdevices_lastupdate ?
I tried:
local now_time = os.date("%Y-%m-%d %H:%M:%S");
otherdevices_lastupdate['Naruszenie strefy'] = now_time;
but it's not working.
Melissen
Post by Melissen »
@Bellison
I saw this LUA script with Json commands.
But how do I get a value (OFFSET) which I entered at a device (ADJUST/AANPASSEN and OFFSET)?
for example I entered an offset at device Watermeter (idx 403), offset is 1184308
How can I read out this value and put it in a value like 'watermeteroffset'? So I can use this value with: otherdevices/svalues['Watermeter'] to get the total amount.
Hope you understand my problem
best regards,
Hein
RFXcom433e ver1009,Raspberry Pi,Domoticz v3.5877
KaKu:16c remote,dimmer,wall-sockets,sunscreenswitch
Promax:wall sockets Elro:wall sockets Somfy:RFY screens
TFA:weather station Chinese temperature sensors, smoke detectors, power switches
