I had a Domoticz installation on a Pi, it was not so stable and updating was a problem even with trying o lot of fixes.
Now i have a Synology DS216play and installed Domoticz on it.
It works very well so the Pi can powered off.
Now i wanna know how to edit the ports used on the Jadahl package for connection with Domoticz.
How can i edit the config of Domoticz like i did with putty on the Pi?
Connecting with the non SSL port works ok, but connecting with teh SSL port doesn't work.
I hope someone can explain how to change this kind of settings,
thanks so far,
Domoticz on Synology - Changing ports editting settings
- Egregius
- Domoticz version: v2024.7
Re: Domoticz on Synology - Changing ports editting settings
The port is set during installation of the package.
Easiest would be to uninstall/reinstall the package.
But, each time you do an update you have to remember to change the ports...
ok, that is not the best option for mee, all switches, blinds, temp, TOON, groups etc are configured now.
where can i update/change the port after an update?
- jumbotroll
The wizard start when you install or update domoticz package and you can change the http and https port. No need to uninstall the old version.
BTW you always take backup of db
If you want to edit the port manually, you can do this in the start-stop-status script located in folder /var/packages/domoticz/scripts
PORT="8084"
RSSLPORT="8443"
PORT="8084"
RSSLPORT="8443"
https://paypal.me/Jumbotroll
Jumbotroll
http://www.jadahl.com
Jumbotroll
- Domoticz version: v3.8153
Hello
I've the samedi problems thé HTTPS ports 8443 dosn't give external acces
