Domoticz on Synology - Changing ports editting settings
sgsdebruijn
Post by sgsdebruijn »
I had a Domoticz installation on a Pi, it was not so stable and updating was a problem even with trying o lot of fixes.
Now i have a Synology DS216play and installed Domoticz on it.
It works very well so the Pi can powered off.
Now i wanna know how to edit the ports used on the Jadahl package for connection with Domoticz.
How can i edit the config of Domoticz like i did with putty on the Pi?
Connecting with the non SSL port works ok, but connecting with teh SSL port doesn't work.
I hope someone can explain how to change this kind of settings,
thanks so far,
Egregius
Domoticz version: v2024.7
Re: Domoticz on Synology - Changing ports editting settings
Post by Egregius »
The port is set during installation of the package.
Easiest would be to uninstall/reinstall the package.
But, each time you do an update you have to remember to change the ports...
sgsdebruijn
ok, that is not the best option for mee, all switches, blinds, temp, TOON, groups etc are configured now.
where can i update/change the port after an update?
jumbotroll
Post by jumbotroll »
The wizard start when you install or update domoticz package and you can change the http and https port. No need to uninstall the old version.
BTW you always take backup of db :-)
If you want to edit the port manually, you can do this in the start-stop-status script located in folder /var/packages/domoticz/scripts
PORT="8084"
RSSLPORT="8443"
https://paypal.me/Jumbotroll
Jumbotroll
http://www.jadahl.com
boris91530
Domoticz version: v3.8153
Post by boris91530 »
Hello
I've the samedi problems thé HTTPS ports 8443 dosn't give external acces
