NEO Coolcam Door/Window Sensor
Pierryck
Post by Pierryck »
I have received my 2 door/windows sensors ZWave Plus from Neo Coolcam.
I can include them with the ZWave USB Stick but in nodes for both, I have:
Type: 0x0000
Enable Polling: No
Status: Sleep
But in the devices list, I cannot see them.
Is there something else to do to enable them ?
lost
Re: NEO Coolcam Door/Window Sensor
Post by lost »
Pierryck wrote:Hi
Type: 0x0000
Enable Polling: No
Status: Sleep
Did you include them using a z-stick, key unplugged & using it's own pairing button (just as it's documentation recommends)?
If so, unpair in the same manner & pair again, but this time from z-wave control panel, z-stick plugged.
Several neo users have reported pairing issues leading to IDs at 0 in the "cheap z-wave chinese products" thread when using the z-stick prefered method (key unplugged).
I myself runned into this problem using neo PIR.
Pierryck
Post by Pierryck »
Thx Lost, it was my case. I kept the z-stick plugged and they are correctly recognized.
For info, the Neo Wall Plug have been recognized with the key unplugged.
Bikey
Domoticz version: 2020.x
Post by Bikey »
I have the same door-sensor. Works fine, except that every time the door opens I not only the the sensor device (xx00) and "access control" device (xx34) get triggered, but also device xx32 Alarm Level and device xx33 Alarm Type are triggered.
The Alarm Type/Level devices however, generate an "Alarm Level Secure" in the Domoticz log on each door event. How can this be prevented?
EddyG
Post by EddyG »
I have the same door sensor and that is working fine.
Did you try to heal the node, + sign at the right. When you try to heal then activate the sensor.
Did you go to the OpenZwave Control Panel? What is show there?
Mine is visible with zwave ID 0x1082 and Type 0003.
Bikey
Post by Bikey »
The sensor works fine, so I don't think it is not included properly.
It's just that it is sending xx32 Alarm Level and xx33 Alarm Type messages as well at each state change.
I have removed these devices from the hardware list, so they are now ignored and no more messages in the log.
Mine is also visible with ID 0x1082 and Type 0003.
micrijn
Post by micrijn »
Hi, Is it needed to put enable polling on YES? I have also set-up a notification I am getting when the window is open, but when it is closed I am not getting an notification... any advice appreciated. Thanks
heggink
Domoticz version: 12451
Post by heggink »
Looking low power zwave devices is not possible as they go in sleep shortly after sending their state and only wake up after a set interval. Reducing the interval drains batteries.
Sent from phone.
DASHTICZ 🙃
P1 meter & solar panel
micrijn
Post by micrijn »
Thanks Heggink, do you have an advice how to set it up? thanks, Michel
micrijn
Post by micrijn »
Sensor sleep.png (86.58 KiB) Viewed 2303 times
micrijn
Post by micrijn »
Here Is show the status from both senors, they sleep. When I push the button in both sensors three times it works for a view minutes and then sleeps again and is not giving an notification when window get's opened or closed
poudenes
Domoticz version: 3.8993
Post by poudenes »
Here I have Neo Coolcam door window sensors as well.. Also in sleep but they ALWAYS send to wave controller when door is open of closed.
I also see this in Domoticz that the sensor is open or close... Even when they are in sleep
So something is not correct in your config
micrijn
Post by micrijn »
Something should be wrong, please check my settings (default) is this the same with you?
Screenshot at Jun 16 14-08-54.png (261.92 KiB) Viewed 2256 times
wube
Post by wube »
Hi Everyone,
I recently bought one and included via Domoticz include instead of manual z-stick include (i have Aeotec Z-Stick Gen5). It shows in the devices and as a node but just like some of you wrote it sends status only for few minutes after include and than falls asleep and doesn't send anything. Did someone got to the bottom of this?
BTW i have neo coolcam PIR sensor since a year and also does the same exact thing.
wube
Post by wube »
Hi Everyone,
Can someone point me to a right direction to set this up so that it works and shows the states all the time and not only for few minutes after inclusion?
