I bought a USB300 enocean controler and 2 devices :
1/ nodon STP-2-1-05 (working properly with Domoticz and controler USB300)
2/ nodon smartplug NOD_ASP_2-1-00
1/ here is the log for temperature device 1 :
2016-12-31 13:13:44.983 EnOcean: 01 (0A/07) A5 08 28 46 80 01 95 8D FB 00 01 FF FF FF FF 56 00
2016-12-31 13:13:44.984 EnOcean: destination: 0xffffffff RSSI: 14
2016-12-31 13:13:44.984 EnOcean: 4BS data: Sender id: 0x01958dfb Status: 00 Data: 46
2016-12-31 13:13:44.985 EnOcean: 4BS, Variant 2 Teach-in diagram: Sender_ID: 0x01958DFB
Manufacturer: 0x46 (NodOn)
Profile: 0x02
Type: 0x05 (Temperature.05)
2016-12-31 13:13:44.987 EnOcean: Sender_ID 0x01958DFB inserted in the database
I can't read the temperature in the Domoticz dashboard. Very good !!
Now with the smart plug
2/ Here is the log for smart plug :
2016-12-31 13:28:48.499 EnOcean: 01 (0D/07) D4 A0 01 47 81 0B 01 D2 01 85 B0 76 88 01 FF FF FF FF 5F 00
2016-12-31 13:28:48.500 EnOcean: destination: 0xffffffff RSSI: 5
2016-12-31 13:28:48.500 EnOcean: teach-in request received from 0185B076 (manufacturer: 147). number of channels: 1, device profile: D2-01-0B
2016-12-31 13:28:48.503 EnOcean: Sender_ID 0x0185B076 inserted in the database
I did a "Learn Light/switch" in "Switches" tab
A windows appeared and ask to push btn on the plug
i gave a name to the new device (odd it is discover like a blind)
Now when i click on the device in domoticz this message appears
"Error sending switch command, check device/hardware !"
IDX Hardware ID Unit
36 OCEAN 958D 251 Temperature EnOcean
37 OCEAN 185B076 1 Smartplug
Smart plug don't work please help !
regards
Nodon ASP-2-1-00 Nodon smart plug
Dany
- Domoticz version: v3.8373
Re: Nodon ASP-2-1-00 Nodon smart plug
I have an ASP-2-1-11 Nodon smart plug.
I can't do anything with this device. Is there any solution for someone?
- enocean3.PNG (16.83 KiB) Viewed 1252 times
- enocean2.PNG (15.71 KiB) Viewed 1252 times
- enocean.PNG (57.13 KiB) Viewed 1253 times
Kangooroo42
hello
same problem here... did you find a solution ?
Kangooroo42
ok I find a solution, I needed to create a virtual enocean device to command this plug
cocof
Bonjour
Pourrais tu détailler ta solution ?
