Help! Adding Roomba with Thinking Cleaner
Goudtik
Post by Goudtik »
Hello fellow enthusiasts,
Recently I started with Domoticz. Currently I use a Homewizard for all of my domotica but I intend to replace this with my Raspberry Pi and a couple of RF-links (433 and 868mhz).
I have a Roomba vacuum that has a Thinking Plate addon so it can be controlled by WiFi (and a couple of Apps). This works seamlessly with my Homewizard but I'd like to use it with Domoticz. Could somebody give me some hints how to do this?
I found a lot of info http://www.thinkingcleaner.com/downloads/TC_API.pdf but I don't know on how to implement this with Domoticz.
Anyone?
Thanks!!!
domogijs
Re: Help! Adding Roomba with Thinking Cleaner
Post by domogijs »
hi
any progress?
Greets gijs
Raspberry Pi3, RFlink, PiZigate, Yeelight, klikaanklikuit, Kodi, harmony hub, Zwave, ThermoSmart, XiaomiGateway (Aqara), Google home hub, roomba,
Skippiemanz
Domoticz version: 4.10233
Post by Skippiemanz »
Here you go https://r.tapatalk.com/shareLink?url=ht ... are_type=t
Get Roomba/Thinking Cleaner Status
domogijs
Re: RE: Re: Help! Adding Roomba with Thinking Cleaner
Post by domogijs »
Skippiemanz wrote:Here you go https://r.tapatalk.com/shareLink?url=ht ... are_type=t
thanks
sam329
Post by sam329 »
Goudtik wrote: Friday 23 December 2016 14:20 Hello fellow enthusiasts,
Anyone?
Thanks!!!
Hello Gouditk,
Thinkingcleaner.com is the best source for every automated related thing.
I hope instead of the above-mentioned URL this url from the same source: http://www.thinkingcleaner.com/setup/api/ will help you better. And at the same time if you want some more in-depth check out this thread: http://www.domoticz.com/forum/viewtopic ... 4&start=20
Hope it helps you the best!!!
Users browsing this forum: willemd and 1 guest
