Hello fellow enthusiasts,
Recently I started with Domoticz. Currently I use a Homewizard for all of my domotica but I intend to replace this with my Raspberry Pi and a couple of RF-links (433 and 868mhz).
I have a Roomba vacuum that has a Thinking Plate addon so it can be controlled by WiFi (and a couple of Apps). This works seamlessly with my Homewizard but I'd like to use it with Domoticz. Could somebody give me some hints how to do this?
I found a lot of info http://www.thinkingcleaner.com/downloads/TC_API.pdf but I don't know on how to implement this with Domoticz.
Anyone?
Thanks!!!
Help! Adding Roomba with Thinking Cleaner
domogijs
Re: Help! Adding Roomba with Thinking Cleaner
hi
any progress?
Greets gijs
any progress?
Greets gijs
Raspberry Pi3, RFlink, PiZigate, Yeelight, klikaanklikuit, Kodi, harmony hub, Zwave, ThermoSmart, XiaomiGateway (Aqara), Google home hub, roomba,
Skippiemanz
- Domoticz version: 4.10233
Here you go https://r.tapatalk.com/shareLink?url=ht ... are_type=t
Get Roomba/Thinking Cleaner Status
domogijs
Re: RE: Re: Help! Adding Roomba with Thinking Cleaner
thanksSkippiemanz wrote:Here you go https://r.tapatalk.com/shareLink?url=ht ... are_type=t
Hello Gouditk,Goudtik wrote: Friday 23 December 2016 14:20 Hello fellow enthusiasts,
Anyone?
Thanks!!!
Thinkingcleaner.com is the best source for every automated related thing.
I hope instead of the above-mentioned URL this url from the same source: http://www.thinkingcleaner.com/setup/api/ will help you better. And at the same time if you want some more in-depth check out this thread: http://www.domoticz.com/forum/viewtopic ... 4&start=20
Hope it helps you the best!!!
