How to upgrade from v2 to v3 (Pi)
snieuwen
Post by snieuwen »
I have been running Domoticz for quite some time now on my Raspberry Pi.
Current version is 2.4031(Compile Date: 2016-01-05 02:44:40).
I have noticed there are no updates available anymore via "Check for updates" in setup menu.
On domoticz.com I can see the newest version available is 3.5877
How can I update to this version? Is it wise to do so? Will it keep all my settings?
(I guess I will need to backup to be sure first)
Egregius
Domoticz version: v2024.7
Re: How to upgrade from v2 to v3 (Pi)
Post by Egregius »
You should always backup :o
When you have a good backup you could even do a clean install of the latest version.
snieuwen
Post by snieuwen »
But what about settings, hardware config etc, from the current config?
Egregius
Post by Egregius »
Those are stored in the database. So backup the database, backup the complete domoticz folder.
jannl
Domoticz version: 2025.5.x
Post by jannl »
Don't forget to backup the scripts directory and the files you changed in the www (sub)dirs.
snieuwen
Post by snieuwen »
Thanks, all worked perfect. First made backup and did new install, now up and running on 3.6207, all settings are fine.
Users browsing this forum: Amazon [Bot], Bing [Bot] and 1 guest
