I have been running Domoticz for quite some time now on my Raspberry Pi.
Current version is 2.4031(Compile Date: 2016-01-05 02:44:40).
I have noticed there are no updates available anymore via "Check for updates" in setup menu.
On domoticz.com I can see the newest version available is 3.5877
How can I update to this version? Is it wise to do so? Will it keep all my settings?
(I guess I will need to backup to be sure first)
How to upgrade from v2 to v3 (Pi)
- Egregius
- Domoticz version: v2024.7
Re: How to upgrade from v2 to v3 (Pi)
You should always backup
When you have a good backup you could even do a clean install of the latest version.
snieuwen
But what about settings, hardware config etc, from the current config?
- Egregius
Those are stored in the database. So backup the database, backup the complete domoticz folder.
jannl
- Domoticz version: 2025.5.x
Don't forget to backup the scripts directory and the files you changed in the www (sub)dirs.
snieuwen
Thanks, all worked perfect. First made backup and did new install, now up and running on 3.6207, all settings are fine.
