HTTP Data Push not keeping url
Rozz
I would like to push data to my Homey with a get http data push, but the URL field will not keep or store the setting, i can save the url and get an http link save confirmation, but when i return to the page the url field is blank.
The url field is located in: Settings - More Options - Data Push - HTTP
Can anyone point me in the right direction or if someone needs more info, please ask me what you need to help me.
For a crosspost to the Homey forum where this problem started:
https://forum.athom.com/discussion/2285/domoticz-data?
Syno DS1512+ => 3Gb Mem, 3x3TB Red, 2x1TB Green.
Asus Maximus VII, Core i7-4790K, 16GB 2400Mhz, 256gb 950Pro, Asus Strix GTX1070, 1xPB287Q + 2xU2412M.
qwerk
Re: HTTP Data Push not keeping url
I have the same problem. see also https://forum.athom.com/discussion/2285/domoticz-data
Are there people where this is working? what version are you using?
qwerk
I found a way around the problem.
don't use the GET option , use the PUT option. then you can save the url and change is to GET.
Now it will stick
Now it will stick
- HansieNL
Still can't get it running here...???
The log doesn't show any httplink push messages.
Blah blah blah
qwerk
You did get the URL saved in domoticz?HansieNL wrote:Still can't get it running here...???
My log is showing the actions.
It only sends data when the data is changed.
- HansieNL
@qwerk: Can't even save the link.
The link I use is : http://192.168.x.xx/api/app/com.internet/%V/%v (x=number
Are you using the same link?
Blah blah blah
qwerk
HansieNL wrote:@qwerk: Can't even save the link.
I am using the same link. Have you seen my earlier post that you can not save the link (first time) when you use the GET statement.
firsttime use the put statement , save it, then you can change it to the GET statement.
benotje
- Domoticz version: V4.20078
the put way works for me also not
Gizmocuz this problem is known ?????
raspberry pi
nas synology
homey
nas synology
homey
- gizmocuz
you can not send me a private message to look at something....benotje wrote:the put way works for me also not
This is also an open source project, this means, you should 'try' at least to compile/debug domoticz, which, under windows, is a piece of cake.
then, if you open the 'chrome' developer console, go to the network tab, and try to save the link, you will see exactly which json call is called.
next, you can search in the code for this command, and you will see where it is checked against, and if you debug step-by-step, you will see where the problem lies.
Took me 3 minutes at the most, without coding skills, to find (and test) the problem. So fixed in #6144
Writing this post took longer... in the feature 'try' at least to debug, it is also a lot of fun !
- HansieNL
I love software but hate bugs
Just bought you a beer
Blah blah blah
- gizmocuz
+1, thanksHansieNL wrote:I love software but hate bugs
Rozz
I updated to Domoticz v3-6147 and used the GET stuff, everything works now!! seeing data being pushed to Homey whenever something changes!
FINALLY!!!!!
FINALLY!!!!!
- homerruma
- Domoticz version: 4.9700
This setings work for my:
The target variable is 1, 2 ,3 e.t.c.
- domoticz4.png (199.67 KiB) Viewed 2115 times
