Error when trying to update to latest Beta
gennapium
- Domoticz version: Stable
When i try to update domoticz on my Ubuntu server is get this error message:
-- Using builtin Mosquitto library
-- Could NOT find PythonLibs (missing: PYTHON_LIBRARIES PYTHON_INCLUDE_DIRS) (Required is at least version "3.2")
CMake Error at CMakeLists.txt:72 (MESSAGE):
Python3 not found on your system, use USE_PYTHON_PLUGINS=NO or sudo apt-get
install python3-dev)
-- Configuring incomplete, errors occurred!
See also "/home/domoticz/domoticz/CMakeFiles/CMakeOutput.log".
See also "/home/domoticz/domoticz/CMakeFiles/CMakeError.log".
make: *** [cmake_check_build_system] Error 1
I have installed Python 3 but is still get this error.
Ubuntu server, Raspberry Pi, PiFace 2, RFXCom, Z-wave Stick, Kaku, Sensor
gennapium
Re: Error when trying to update to latest Beta
Anyone ?
gennapium
I really need to update to the latest Beta version on my Ubuntu server.
SweetPants
I had the same issue on my ubuntu server.
If you don't need python3 support:
cmake -DCMAKE_BUILD_TYPE=Release -D USE_PYTHON_PLUGINS=NO CMakeLists.txt
make
make
- Dnpwwo
Hi gennapium,
The error actually says to not to install python3 itself.
Give that a go.
sudo apt-get install python3-devGive that a go.
SweetPants
That does not work!!!Dnpwwo wrote:Hi gennapium,
The error actually says tonot to install python3 itself.Code: Select all
Give that a go.
- Dnpwwo
If installation of python3-dev does not work it is most likely because the cmake version is really old.
It will need to be at least at version 3 to pick up python properly, if you can't upgrade cmake to version 3 (latest I've seen is over 3.6) then you should indeed use:
cmake -DCMAKE_BUILD_TYPE=Release -D USE_PYTHON_PLUGINS=NO CMakeLists.txtThe reasonable man adapts himself to the world; the unreasonable one persists to adapt the world to himself. Therefore all progress depends on the unreasonable man. George Bernard Shaw
gennapium
Hallo,
I did install:
But the problem still exists.
I did install:
gennapium
Ok,
I will give this:
a try this evening. See what happens.
I will give this:
- Dnpwwo
Are you running Ubuntu 12.04? If so that has an ancient cmake. You can tell by running:
There is a backport avaiable, have a look here https://launchpad.net/~george-edison55/ ... -backports or you can build it from source here http://askubuntu.com/questions/679299/i ... tu-precise and get a newer version
cmake --versionThe reasonable man adapts himself to the world; the unreasonable one persists to adapt the world to himself. Therefore all progress depends on the unreasonable man. George Bernard Shaw
SweetPants
14.04 LTS also has an old version by default.Dnpwwo wrote:Are you running Ubuntu 12.04? If so that has an ancient cmake.
gennapium
I am running Ubuntu 14.04.
SweetPants
Same problem
sudo apt-get install build-essential
wget http://www.cmake.org/files/v3.2/cmake-3.2.2.tar.gz
tar xf cmake-3.2.2.tar.gz
cd cmake-3.2.2
./configure
make
sudo make install
cd cmake-3.2.2
./configure
make
sudo make install
gennapium
cd cmake-3.2.2
./configure
make
sudo make install
This is the solution ?
cd cmake-3.2.2
./configure
make
sudo make install
SweetPants
yesgennapium wrote:This is the solution ?
gennapium
Great, i will try it this evening.
gennapium
cd cmake-3.2.2
./configure
make
sudo make install
This did not solve the problem, this however did:
cd cmake-3.2.2
./configure
make
sudo make install
SweetPants
It did for me. If you need python3 support later you will run into the same problem again. Better upgrade cmake to version 3.2.xgennapium wrote:This did not solve the problem, this however did:
Did you get any errors after the install of the new cmake?
- jumbotroll
Hi.
Trying to cross compile with pluginmanager for all synology NAS.
Compile with cmake -DCMAKE_BUILD_TYPE=Release -D USE_PYTHON_PLUGINS=NO CMakeLists.txt working ok.
The latest Python3 for Synology is Python3.5.1.spk, but if I try to cross compile with Python 3.5.1 it's failed.
If I cross compile with Python3.4.1 all is ok, but domoticz give this error: 2016-12-13 22:07:35.344 Error: PluginSystem: Failed load 'libpython3.5.so', Python probably not installed on system.
Is it possible to change this plugin to accept Python 3.4 and 3.5?
BTW using Cmake 3.2.2
https://paypal.me/Jumbotroll
Jumbotroll
http://www.jadahl.com
Jumbotroll
- Dnpwwo
Hi Jumbotroll,
Functionally it will work with Python 3.2 and above (test 3.2, 3.4, 3.51 & 3.5.2), I'm in the process of trying to work out a reliable of locating the libarary on differnt flavours of Unix and different versions of Python and how to have a version out very soon.
