Error when trying to update to latest Beta
gennapium
Domoticz version: Stable
Post by gennapium »
When i try to update domoticz on my Ubuntu server is get this error message:
-- Using builtin Mosquitto library
-- Could NOT find PythonLibs (missing: PYTHON_LIBRARIES PYTHON_INCLUDE_DIRS) (Required is at least version "3.2")
CMake Error at CMakeLists.txt:72 (MESSAGE):
Python3 not found on your system, use USE_PYTHON_PLUGINS=NO or sudo apt-get
install python3-dev)
-- Configuring incomplete, errors occurred!
See also "/home/domoticz/domoticz/CMakeFiles/CMakeOutput.log".
See also "/home/domoticz/domoticz/CMakeFiles/CMakeError.log".
make: *** [cmake_check_build_system] Error 1
I have installed Python 3 but is still get this error.
Ubuntu server, Raspberry Pi, PiFace 2, RFXCom, Z-wave Stick, Kaku, Sensor
gennapium
Re: Error when trying to update to latest Beta
Post by gennapium »
Anyone ?
gennapium
Post by gennapium »
I really need to update to the latest Beta version on my Ubuntu server.
SweetPants
Post by SweetPants »
I had the same issue on my ubuntu server.
If you don't need python3 support:
cmake -DCMAKE_BUILD_TYPE=Release -D USE_PYTHON_PLUGINS=NO CMakeLists.txt
make
Dnpwwo
Post by Dnpwwo »
Hi gennapium,
The error actually says to
sudo apt-get install python3-dev
not to install python3 itself.
Give that a go.
SweetPants
Dnpwwo wrote:Hi gennapium,
Give that a go.
That does not work!!!
Dnpwwo
Post by Dnpwwo »
If installation of python3-dev does not work it is most likely because the cmake version is really old.
It will need to be at least at version 3 to pick up python properly, if you can't upgrade cmake to version 3 (latest I've seen is over 3.6) then you should indeed use:
gennapium
Post by gennapium »
Hallo,
I did install:
But the problem still exists.
gennapium
Post by gennapium »
Ok,
I will give this:
a try this evening. See what happens.
Dnpwwo
Post by Dnpwwo »
Are you running Ubuntu 12.04? If so that has an ancient cmake. You can tell by running:
cmake --version
There is a backport avaiable, have a look here https://launchpad.net/~george-edison55/ ... -backports or you can build it from source here http://askubuntu.com/questions/679299/i ... tu-precise and get a newer version
SweetPants
Dnpwwo wrote:Are you running Ubuntu 12.04? If so that has an ancient cmake.
14.04 LTS also has an old version by default.
gennapium
Post by gennapium »
I am running Ubuntu 14.04.
SweetPants
Same problem
sudo apt-get install build-essential
wget http://www.cmake.org/files/v3.2/cmake-3.2.2.tar.gz
tar xf cmake-3.2.2.tar.gz
cd cmake-3.2.2
./configure
make
sudo make install
gennapium
Post by gennapium »
cd cmake-3.2.2
./configure
make
sudo make install
This is the solution ?
SweetPants
gennapium wrote:This is the solution ?
yes
gennapium
Post by gennapium »
Great, i will try it this evening.
gennapium
Post by gennapium »
cd cmake-3.2.2
./configure
make
sudo make install
This did not solve the problem, this however did:
SweetPants
gennapium wrote:This did not solve the problem, this however did:
It did for me. If you need python3 support later you will run into the same problem again. Better upgrade cmake to version 3.2.x
Did you get any errors after the install of the new cmake?
jumbotroll
Post by jumbotroll »
Hi.
Trying to cross compile with pluginmanager for all synology NAS.
Compile with cmake -DCMAKE_BUILD_TYPE=Release -D USE_PYTHON_PLUGINS=NO CMakeLists.txt working ok.
The latest Python3 for Synology is Python3.5.1.spk, but if I try to cross compile with Python 3.5.1 it's failed.
If I cross compile with Python3.4.1 all is ok, but domoticz give this error: 2016-12-13 22:07:35.344 Error: PluginSystem: Failed load 'libpython3.5.so', Python probably not installed on system.
Is it possible to change this plugin to accept Python 3.4 and 3.5?
BTW using Cmake 3.2.2
https://paypal.me/Jumbotroll
Jumbotroll
http://www.jadahl.com
Dnpwwo
Post by Dnpwwo »
Hi Jumbotroll,
Functionally it will work with Python 3.2 and above (test 3.2, 3.4, 3.51 & 3.5.2), I'm in the process of trying to work out a reliable of locating the libarary on differnt flavours of Unix and different versions of Python and how to have a version out very soon.
