Hi i am new here.
I have everyting working so far.
but my Temp + Humidity sensor is in the wrong place. (i think)
it must be in the weather section now in the temp section, how can i change/correct this?
I use a Raspberry serie B+ and a RFLink with firmware 44.8 and a Alecto WS3500 weather station.
The latest domoticz version 3.5877
I see rain and wind ( no outside temp) in the weather section but there is no chill calculation, it is always "0"
i hope some one can help me with this.
No chill calculation WS3500 Alecto
- mrccore
- Domoticz version: 3.5877
Re: No chill calculation WS3500 Alecto
Hi.
I'm having the same issue you have.
Normally the Temp+Humidity stays on the Temp sector and on the Weather sector on the wind value card we should have the temp and the chill values.
At this moment i don't have any off these values i'm getting chill value "0" don't now why.
Other thing i cant see is the wind speed... cant get value off speed and direction.
What i would like to now is why we don't get the pressure value on domoticz?
I have the latest domoticz version 3.6... and RFLink fw R44.8
- mrccore
One other thing i'm getting is always the NNE direction and the values 23 and 45 NNE very strange.
At this moment i don't have the LCD turned ON so the outside station is transmitting only to the RFLink
PeJeWe
- Domoticz version: Latest
I also whant the pressure.
maybe there is a way to connect an transmitter to our inside unit somewhere.
i have not yet found out how to get the wind chill factor.
- Stuntteam
The windchill is usually calculated in Domoticz (based on temperature and wind speed). Most sensors do not send this.
PeJeWe
i think that domoticz place the sensor at the wrong place it should be the weahter statoin section and not regular temp sensors.Stuntteam wrote:The windchill is usually calculated in Domoticz (based on temperature and wind speed). Most sensors do not send this.
how can we correct this?
when this is correct i hope that domoticz will calculate te wind chill.
Xztraz
same trouble with acurite weather sensor via rflink. always get -1.9 degrees chill.
