No chill calculation WS3500 Alecto
PeJeWe
Domoticz version: Latest
Post by PeJeWe »
Hi i am new here.
I have everyting working so far.
but my Temp + Humidity sensor is in the wrong place. (i think)
it must be in the weather section now in the temp section, how can i change/correct this?
I use a Raspberry serie B+ and a RFLink with firmware 44.8 and a Alecto WS3500 weather station.
The latest domoticz version 3.5877
I see rain and wind ( no outside temp) in the weather section but there is no chill calculation, it is always "0"
i hope some one can help me with this.
mrccore
Domoticz version: 3.5877
Re: No chill calculation WS3500 Alecto
Post by mrccore »
Hi.
I'm having the same issue you have.
Normally the Temp+Humidity stays on the Temp sector and on the Weather sector on the wind value card we should have the temp and the chill values.
At this moment i don't have any off these values i'm getting chill value "0" don't now why.
Other thing i cant see is the wind speed... cant get value off speed and direction.
What i would like to now is why we don't get the pressure value on domoticz?
I have the latest domoticz version 3.6... and RFLink fw R44.8
mrccore
Post by mrccore »
One other thing i'm getting is always the NNE direction and the values 23 and 45 NNE very strange.
At this moment i don't have the LCD turned ON so the outside station is transmitting only to the RFLink
PeJeWe
Post by PeJeWe »
I also whant the pressure.
maybe there is a way to connect an transmitter to our inside unit somewhere.
i have not yet found out how to get the wind chill factor.
Stuntteam
Post by Stuntteam »
The windchill is usually calculated in Domoticz (based on temperature and wind speed). Most sensors do not send this.
PeJeWe
Post by PeJeWe »
Stuntteam wrote:The windchill is usually calculated in Domoticz (based on temperature and wind speed). Most sensors do not send this.
i think that domoticz place the sensor at the wrong place it should be the weahter statoin section and not regular temp sensors.
how can we correct this?
when this is correct i hope that domoticz will calculate te wind chill.
Xztraz
Post by Xztraz »
same trouble with acurite weather sensor via rflink. always get -1.9 degrees chill.
