Housing for outdoor UV sensor ? What to use as "window" that wont block UV ?
Redguy
Domoticz version: 3.5877
Post by Redguy »
I would like to add a regular and a uv light sensor to my setup to measure outdoor light en uv intensity.
The sensors itself should no be too hard.. But I am struggling with the housing for the sensors.
I would like to protect the sensors from the environment bus as far as I know, even regular glass filters out a lot of the UV light.
So what to use to protect the UV sensor, but still get a good reading from the sensor ?
oopee
Domoticz version: 3.x
Re: Housing for outdoor UV sensor ? What to use as "window" that wont block UV ?
Post by oopee »
I have the sensor part but haven't got time/inspiration to do assembly of the actual device yet... but I was going to do tests with a box with a hole covered with microscope slide cover slip. That is very thin piece of glass that covers the specimen. My daughter has a microscope (kind of a toy) with plenty of those. Maybe it is so thin that it won't block too much UV.
Toulon7559
Domoticz version: <2025
Post by Toulon7559 »
Same kind of discussion here
